Question about Kitchen Appliances - Others
Wont cut off when boiled - Kitchen Appliances - Others
    Problem Solver:
  • 10 Answers
Termostat is damaged or faulty . to check put kettle on boil but fold a kitchen towel in four and lay on top of kettle cover spout and handle . the kettle shut off at boiling point if not its faulty. some models you cant repair .
Posted on Apr 02, 2015
  • 937 Answers
Is the kettle lid fully down? If not then the sensor won't get hot enough to activate the power cut off sequence. If all this is OK then consider junking the kettle for a new one. Obviously, if you are attached to kettle then take it to a reputable repairer. If the kettle is a fairly cheap one he should suggest replacing it.
Can i freeze boiled potatoes cut in small pieces
sure place them on a cookie sheet and freeze then place them in a zipbag and they wont stick together
Dec 18, 2016 | In Microwave Ovens
What info do you need?
This answer may be too late but first clean this thoroughly with vinegar. Try now to see if anything changed but do a very thorough clean.
Nov 08, 2013 | Chef's Choice Electric Cordless French...
Whasing machine boils on all programs
sounds like a thermostat problem not cutting off the heater when selected temperature is reached
Feb 09, 2013 | Indesit Washing Machines
1989 supra will start and run fine untill it is warm, then it will cut off and wont start back untill it is cold again. WHATS WRONG???
dont no about that but check coil pack when it wont start and see if you have spark if it doesnt check for power to coil if you have spark its on the fuel side
Jan 10, 2013 | Toyota Supra Cars & Trucks
The switch does not automatically turn off when the water boils. If left alone all the water will boil out.
The switch has to turn off when the water boils as the heat generated must cut off the switch. If this wont work the bimetal is not working and the switch is not responding.
You will need to replace the switch. Please contact the dealership for the spare.
check this link for spare:
http://www.espares.co.uk/brands/kettles/p/1102
Sep 21, 2011 | Oster (3211) Electric Kettle
Over heating
hi the first thing to check would be the thermostat, if you remove the thermostat and have a look at it then boil some water then put it in the boiling water then wait 30sec take it out with something so you wont burn yourself then check if it has opened to allow water to pass through, if not replace.
the other thing to check would be to see if the rad fan cuts in when the temp gets hot if not then the rad switch may need replacing.
check thermostat first as this is the most likely cause of your problem.
other problems could be as bad as head gasket but this would be last resort to check head gasket you need to do compression test or have a sniff test done.
let me know how you get on or if you need further assistance ok
Jun 04, 2010 | 2001 Cadillac DeVille
The power switch light on my kettle comes on but it wont boil
1. Check the continuity on the power switch
2. Check to see if any thermal cut-out is open circuit
3. Check to see if the element has gone open circuit.
Any open circuit indicates the part will require replacing. Given the cost of the kettle, if the element has gone open circuit it may be worth considering replacing the kettle itself.
Mar 25, 2010 | Russell Hobbs RHOK3123 Cordless Electric...
I have a gilera runner 50 sp and it wont start
Has it been laid up for months? Did you leave any gas in it untreated? You may need to boil out the gas tank . Try a carb cleaner first that you add to the gas.Check the plugs.Are they black/oily (too rich / worn ring), Tan ( correct ).they tell a lot about the condition of the engine. Good Luck
Sep 15, 2009 | 2005 Gilera Runner VX 125
Do i have a vapor lock
Remove the gas cap when it does this. If you hear a woosh sound the tank vent isn't working properly. Essentially your tank has turned into a vacuum.
Jun 10, 2008 | 1996 Ford Taurus
Kitchen Appliances - Others Logo
632 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
