Question about Samsung RS263 Black Side-By-Side Refrigerator - RS263TDBP
The fridge is not cooling, coils frozen, need to access
I have pulled out all the screws, the cooling drawer, etc. I can't seem to get the panel off in the back of the interior. I have watched videos on how to defrost in case it's frozen, but I can't get the panel off and I am afriad I am going to crack it or break it. any tips and or tricks to get that panel off?
  • Samsung Master
  • 3,382 Answers
My preference is to empty the unit then use a normal fan blowing into the unit. As the ice melts I just use towels to mop it up. I keep the fans on until the surfaces are dry. Works every time.
Posted on Apr 02, 2015
    Sergeant:
  • 314 Answers
It is freezing over because it is either low on refrigerant charge (and super cooling) or the defrost timer is bad (stuck without ever going through defrost cycles.
    Scholar:
  • 98 Answers
I believe the panel you want to remove is the lower vent panel. It should come off just by removing the 4 screws. If you have ice buildup it may be holding it in place. Use a hairdryer to defrost. Be cafreful, hair dryers and puddles of water don't mix well... Here is a link to your manual for some troubleshooting options. So unplug, defrost, then reconnect power.
http://downloadcenter.samsung.com/content/UM/201006/20100625100458859/DA68-01890N.PDF
Whirlpool Gold side by side refrigerator air scoop
Sounds like it may be the air deflecter, it is in the back right corner of the freezer at the top. It deflects the air coming from the evap fan, into the fridge damper.
Aug 27, 2012 | Refrigerators
Water dripping from freezer into refrigerator
Hi,Most likely the drain in the freezer is clogged up and frozen. Every time when your fridge automatically defrosting defrosted water dripping inside the fresh food compartment. You have to remove the back panel in the freezer and using a hair dryer defrost the drain which is located under the evaporator coil. Then put very hot water through the drain until it goes free.
Yes, you need to remove the back panel inside the freezer, It should have screws that come out then it should pull off and out.
On your model, the defrost drain hole/line is located inside of the freezer behind that back access panel, just remove that back panel, remove your freezer floor panel FIRST(Has 2 screws in front), that simply pulls out, then you will see the drain hole under the evaporator coil. It may be iced up, you will have to clear all of the ice and run hot water down the drain hole.
Once the back panel screws are removed that panel should just pull off, pull hard. Make sure your refrigerator is unplugged first.
Good luck.
May 28, 2011 | Kenmore Top Freezer Refrigerator
Frozen solid freezer, warm refrigerator. (model Amana bottom freezer abb1922few) Can see frost on freezer foods and back vents (almost occluded). Just vacuumed wads of dog hair/dust off of front half of...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Refrigerators
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Pds GE Profile Bottom-Freezer Drawer...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer and fridge is warm, cold air blowing but freezer is still
Try this, I went to the freezer side pulled the inside back panel (had to defrost it to get it out) and it was completely frozen over. It was not not operating properly because the cooling coils would not allow the fan to pull air through them to cool the refrigerator side. I completely defrosted the coils and turned the refrigerator back on, it worked fine. I then ordered a new adaptive defrost assembly (this is the thing that prevents the ice buildup) since ours was apparently not working properly. I used a fan too speed up the defrost process, because i had to take all the frozen food out and put it in a cooler to get to the back panel. After you take out the racks and food you only need to remove two screws that have a 1/4' head. good luck.
Mar 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
The freezer is not cold enough - ice-cream is soggy! despite putting it on coldest; and the red warning light is permanently on. And I can't find the booklet. Help!
If the coils are frozen up already,putting the setting to coldest is the worst thing to do.Even though inconvenient,try unplugging for substantial amount of time (3 or 4 hours) to allow the coils to defrost.Be prepared for water leakage during this time.If this seems to work , chances are the defrost timer or defrost heating element are bad and the problem will recur after a week or two.
Jan 17, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
High temp red light stays on...
You'll need to tear into it to answer these questions. I suspect the defrost cycle isn't working or the fan is broken. The best way to see what's going on is to take everything out the freezer drawer and remove it. Then take the back panel off the interior rear wall of the freezer section to expose the coils. The coils should have a very even white frost pattern on them (not frozen solid anywhere). If they are frozen up then the air can't flow around them to cool the fridge properly. If the coils seem "normal" with frost only then is the fan just above them working? That fan circulates cold air to both fridge and freezer sections. Let me know what you find out in order to lead you to a repair part.
Jan 12, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Freezer working fine, but Refrigerator no longer cooling
Sounds like there's an airflow problem to the top section. Things that cause no cold air to the top fridge section are... frozen up coils completely blocking most of air flow (defrost cycle not working), evap fan not working to blow air up to fridge, air control dampers in fridge closed or not working properly, or frozen air ducts supply/return. Pull the whole drawer out the bottom and take the rear inside back off to expose the coils. If they are frozen solid the defrost t-stat or defrost timer could be bad (heat element not usually bad). If there is a nice white frost all over evenly then that's OK. Check that the fan is running when the compressor is running to blow the air up and that there are no blocked air ducts, etc. If all that is good, check if you can feel good air flow from the upper vents with the lower door closed (that shows there is no blockage and the fan is running).
Jan 06, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Samsung RS263 Black Side-By-Side Refrigerator - RS263TDBP Logo
234 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
