Question about Miele Dishwashers
I have a Miele G 692 SC plus dishwasher and the filter is stuck. The plastic part turns, but the filter will not come out of the slot.
2 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Posted on Feb 25, 2009
Water intake alert coming on however the water is turned on. No water seems to be entering the dishwasher.
No water intake, may be a defective intake hose valve. Miele calls it, the Waterproof System hose (WPS). However, first shut off your water valve to the dishwasher; disconnect the WPS; and inspect and clean the plastic filter. If the problem persists, then replace the WPS (~$170).
Oct 17, 2010 | Miele Premier-Plus Built-in Dishwasher
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Miele Turbomatic G590 SC Not enough water
See page 31 of the manual for possible solution. The manual is here: http://miele.com/manuals_pdf/Residential/Dishwashers/English_manuals/Operating_Instructions/G590_us.pdf
Aug 29, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
I need the rail stopper on the left hand side of the top rack. It is a plastic v shaped piece or I need the whole rail. Modle #G885 SC dishwasher miele do you know where I can order this?
The only place to order Miele parts is through Miele spare parts. You can find your nearest Miele office through their website. There are no copy parts available.
Aug 08, 2009 | Miele 24 in. G643Vi Plus Built-In...
Feb 25, 2009 | Miele Dishwashers
I have a Miele G841 SC Plus Novotronic Dishwasher. The Intake/Drain light is blinking and it won't work. What do I do?
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Sep 15, 2008 | Miele 24 in. Novotronic G842 Plus Built-in...
Miele g 646 sc (not plus)
check the inlet where it joins onto the tap as mine has a fine filter and debris from the fresh water builds up. Simply remove the pipe from the tap and **** ,this should remove /dislodge any scale etc that could be causing the inlet light to come on. Make sure you spit out the water that comes back from the machine!
Apr 20, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele Model G 692 SCI PLUS does not start up. It drains water if you put water in the bottom. The Inlet/Drain light flashes. I have checked all the water filters and cleaned any very small particles...
The inlet/drain light also comes on when there is water in the base pan. There is a float switch that triggers this and over time if water has collected in the base pan the float switch can stick. Pull out the dishwasher and tilt it towards to back. If there is any water in the base pan it will come out. To be thorough, put the machine on it's back and remove the base pan (4 screws by the feet), the float switch is a circular plastic casing with a polystyrene float in it. It comes apart for servicing, the float can jam if there is any rubbish in the water.
Apr 02, 2008 | Dishwashers
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
99 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
