Why does it lockup?
OK, I can be scanning & it will lockup 3 or 4 times, all I can do is wait till it unlocks.
  • 739 Answers
Have yet to see a laptop that scans. sounds like you have a scanner attached to one, and are asking why the laptop locks up during the scanning process.
the biggest issues are: a 'registry' that isn't working at optimum and total available memory. Glary Utilities, is a free for private use program suite that can keep all the 'gremlins' at bay as far as your registry's functionality available through: glarysoft.com I recommend it. Its free and works.
Secondly, look into upgrading your memory for your laptop. Scans are pictures and generally require loads of memory. If you can upgrade? Do it.
Posted on Apr 02, 2015
Too many patterns attempts and the phone was locked
Reset your Galaxy Y s 5360
All your phone data (contacts,photos,messages, aplications,games,files) will be lost Please make backup first if you can!
1.Power off your phone
2.Press together volume up +home button+power button
3.Wait till appears samsung logo second time
4.Leave your fingers down tot the buttons
5.Select "wipe data" with volume buttons
6 Press "home" button to activate
7.Select "yes"
8.Press "home" button to activate
9.Wait till format it's over
10 Select rebot
good luck
Mar 05, 2014 | Samsung Galaxy Y Gt-s5360 - White unlocked...
How do you run channel auto scam
HI,
To auto preset channels do the following procedure.
1. Press the SETUP button on the remote.
2. Using UP/DOWN arrow Select CHANNEL SET UP and press the RIGHT arrow to enter to channel preset
3. Using UP/DOWN arrow select AUTO PRESET and press the RIGHT arrow to start the auto scan.
Wait till The tuner scans and memorizes all the active channels in your area.
ok
Sep 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Unlock portable dvd philips pd9000 for all regions (region free)
Try this:1. Turn on player.
2. Open disc tray.
3. Wait till 'Open' appears on screen
4. Type 9 6 5 3
5. Press up or down button to reach REGION option
6. Press OK button
7. Scroll UP/Down to TEST0 , press OK
8. Press setup again to exit
Let me know if it works!
Sep 19, 2010 | Philips PD9000 Player
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
I
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
II
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
Do you have virgin codes for eurovox
you need to reset box and then re insert codes from before
Jun 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
HP C5180 error messsage Oxc19a0024 will not print. what to do.
Ok this is a old postint but you may come back to see it or it may be handy for some one elles.
Solution 1:
Solution 2:
  17. All the best: Pineworks
Jun 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Ink system has failed: Error oxc18a0306
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
4- Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
5- Press both cancel and power button at the same time.
6- Message on printer screen will be, "Enter Special Key Combo".
7- Push keys; Left-Ok-Right.
8- When printer screen changes, scan through and look for "System Menu" and push "Ok"
9- Scan agan and look for "Clean Derivative" and push "Ok". [WAIT FOR 1 MINUTE].
10- Scan agan and look for "Clean Firms" and push "Ok". [Again WAIT FOR 1 MINUTE]
11- Press "Cancel" 4 times
12- Turn off power and unplug from power source. [NOW WAIT FOR 2 MINUTES].
13- Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
14- Plug in power source,and turn on power.
15- When printer boots up, answer the questions on the printer screen for your area.
16- The printer will cycle the ink from the cartridges to the print head and back.
May 20, 2008 | HP Photosmart D7160 InkJet Printer
Help!!!
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
Mar 18, 2008 | HP Photosmart D7160 InkJet Printer
Computers & Internet Logo
David Payne
David Payne
