Question about Ovens
How do I set in a program so that the oven switches on at midnight and reaches 130degrees then switches off at 7am
  • 739 Answers
The real question is, why the heck would you want this?
From the question is seems as if you want to use your oven as a heat source for your home. DON'T DO THIS!!!!!! Not only will you burn out the stove, but you risk a fire hazard and endanger your family!
Another inference is that your primary heat source, most likely natural gas, has been shut off due to non-payment. Pay the bill, get the gas turned back on, and keep your family safe and warm.
Posted on Apr 02, 2015
How do I program the above controller on an industrial oven to switch on at midnight then off at 7am can anyone help
Easiest way would be to get a 220 VAC pool timer, and wire it into the stove circuit.
Apr 02, 2015 | Ovens
Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Dec 06, 2007 | Electrolux EOB6632 Electric Single Oven
Kenmore 7909445 oven not reaching specified temperature?
The User's Manual says that the minimum temperatures for most settings is 170F. If those are also the defaults, the oven controls might have forgotten their settings and might need to be reset. If resetting the controls doesn't work, you might want to try checking the temperature sensor; sensors go more frequently than control panels do. I have included a link to the User's Manual I found.
http://www.saferproducts.gov/Common/Pages/DisplayDocument.aspx?documentId=294072
May 23, 2014 | Kenmore Ovens
We bought a deDietrich oven UMP412 (Ser No 02-24-06004) on 31/08/2002. Recently the heater behind the in-oven fan blew and was replaced together with the lower heater (which was found failed) and main...
Hi Maurice.
Circulating is Fan Assisted mode. In this mode the fan kicks in when temperature is reached and runs all the time.
Here an extract from manual.
There is no preheat unless you set temperature. That is why you get the fan from start.
Oct 20, 2011 | De Dietrich Ovens
How to program the buttons and times?
does oven need to reach its temp to program? what screens are you suppose to use to perpare food? need help programming the turbo c3!!!!
do you have any chefs that are in the west palm beach,fl area that could possible help us program this unit?
Mar 26, 2010 | TurboChef C3 Single Oven
Can not alter temprature from fixed setting
to decrease or increase temp we use a button or switch and this switches reach order for control board as a general basis so if the tow functions - & + faulty together then i think it is the control board need to change
Jul 09, 2009 | Neff B4540 Stainless Steel Electric Single...
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Oven not reaching correct temp
It isn't a design flaw. It is an air pressure switch. Main fan not running OR oven is dirty and the tube to the air pressure switch is clogged. Dirty ovens aren't a design flaw. I saw it once a week. Five minutes clearing the tube and you back in business. Hope this helps.
Jan 13, 2009 | Lincoln Conveyor Oven - 1133-000-A
Ovens Logo
60 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
