Question about John Deere Garden
Mower lift lever wont move
X550
4 Suggested Answers
SOURCE: Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
Posted on Apr 05, 2010
ftw1952
  • 10319 Answers
SOURCE: I just installed a 48"
study the photo in the webpage link as given below for towards the rear of the cutting deck you will see a left and right side support for the swing arms on the handle that slides into the eyelets of these 2 supports. the frong has two bars, left and right that attach to the front from the front axle area. locking pins hold these rods in place shape like a hair pin
https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LX178_48deckLawnTractor.pdf
Posted on Apr 23, 2011
SOURCE: Hi I have a John Deere 345 lawn mower and the deck
Sounds like the deck is frozen up.
and the other sounds like a belt issue.
Posted on May 05, 2012
Lift won't raise
The lift lever is connected by bars and or chains. It is possible that the chain has come of or that a bolt at a lever pivot point has broke, Look at the top of the mower deck and have someone move the raise control lever up and down. You should see the problem.
Mar 19, 2015 | Garden
Toro zero turn mower wont move
there is a parking brake turn it off if that still dont work check your hydrolic lines
Jan 21, 2014 | Garden
I have a lawn mower that has a hydraulic lift - and frequently it will not lift the mower deck or snowblower unless I push down on the lift assembly arm (it is connected to the mower by chains) while I...
Larry,
I have a Troy built x20 lawn tractor and the lift cylinder moves until the weight of the blade is on it and then it stops. Sounds like we have the same problem. Any luck with yours? ANy answers out there. Again, the cylinder will move raise and lower until the weight of the blade is applied. The left to right cylinder will move but very slowly. Any ideas from anyone would be appreciated.
Tim
Dec 17, 2010 | Garden
LIFT ARMS FOR 3 POINT HITCH WILL NOT MOVE, NOT SURE WHAT CONTROLS OPERATE
Standard tractors have a lever to the right of the driver, move toward the rear of the tractor to lower ... move toward the front to lift.
May 07, 2010 | Garden
Lawnmower wont move in fwd or reverse
Is the brake sticking. On my craftsman mower there is a bar under the brake pedal that pushes back a lever when starting. And the lever sticks. I have to reach underneath and pull the lever forward and then the mower goes. I haven't found a solution to that yet.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
Dec 06, 2009 | Ariens Garden
The blade engage lever on my 42" craftsman mower will not disengage completely
Get a can of penatating oil and spray the pivot point of the idler arm on the deck. That's the one that moves back and forth when you lift the blade engagement lever.
Jun 06, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
