Question about PIAA 2006 Suzuki Grand Vitara - All Grand Vitara models - Xtreme White Bulbs
4wd stops engaging after new tyres fitted on Suzuki vitara
Instruction on how to engage 4 wheel drive 89 mod
mod?
vitara , sidekick and tracker are same car.
so..
be on ice, or dirt then, engage 4wd by moving lever to 4wd (4H)
at about 1/2 mph after locking hubs. (89 is manual hubs)
http://www.fixkick.com/part-time-test.html
Mar 17, 2015 | Suzuki Vitara Cars & Trucks
How do i remove front hub
hello anon.
2wd or 4wd car?, this Counts big time? i toss coin; land 4wd.
The USA car can be Vitara or Grand Vitara. and cut in dates vary for that too.
the 2002 has no end locking hubs.
so you must mean front wheel bearing hubs.
ok its easy with tools.
GOT TOOLS?
http://www.fixkick.com/hubs/FW_BEARINGS.html#newer
to be accurate i need full spec on car
country
engine sizes. and if 2wd or 4wd.
my guess is your car has the unified hubs. (bearings can not be removed)
you unbolt it.
you put the new hub on
you torque it to 123-180 Ft/lbs, this is the running torque not a preload)
if not, it will fail fast.
that page even has the FSM chapter page there. to see.
from a real Suzuki, 2004.
can be seen tool, at alldata.com
or at suzuki pit stop , dot com (google it) its there.
Sep 27, 2014 | 2002 Suzuki Vitara
05 gmc 4 wheel drive will not engage
Suzuki GMC?
which is it?
not engage, the lamp or real 4wd
did you try dirt,? or on top of ice yet?
Mar 06, 2014 | 2007 Suzuki Grand Vitara 4WD
I have a Suzuki 2L diesel 2004 Grand Vitara and recently the 4x4 does not disengage even though i have put the lever back down to 2. Eventually after a few hundred metres it disengages back to 2 wheel...
hello and greetings. you did not say what driveline options
were purchase when car was new. so, can not answer.
but if car is PT 4wd, I can. if not get it fixed, by any 4wd shop.
the car is full time 4wd or AWD ?
PT:
the Part time 4wd must not be driving on dry pavement.
so drive to dirt or grass or ice and then shift back to 2wd
there is a TSB from Suzuki on wind up.
exceptions?
sure , the 2004 options statement here. and the rules for PT 4wd.
Suzuki Grand Vitara/Escudo -full-time 4WD using limited-slip center differential, off-road 4WD with selectable center differential lock and low range transfer case 4 mode (4h, 4h lock, 4l n), traction control and electronic stability control
Suzuki offered as an option AWD for Grand Vitara's in 2004 (XL7 too) Some Suzuki AWD you can not use lock on dry pavement, so read the operators guide carefully.
suzuki sells the operators guide if lost,
$4 day pass
$25 for full pdf.
https://suzukipitstopplus.com/Products/1042-2004-grand-vitara-owners-manual.aspx
Mar 01, 2014 | Suzuki Cars & Trucks
4 wheel drive will not engage F150
a 2007 Suzuki Grand Vitara 4WD F150
huh?
Feb 13, 2014 | 2007 Suzuki Grand Vitara 4WD
4 wheel will not engage
define engage.
1: lamp glows. (means almost nothing... 1switch 1 lamp, zip)
2: 1 tire slips on front and rear on ice.? (works for real,it does.)
are you driving on dry pavement (no ice) in 4wd
stop that
, this is part time 4wd, its not AWD. at all
see the rules , even the lost operator guide rules, and why.
and how to do the tests. wheels up or wheels down.
always post road surface with 4wd,
ice
snow
dirt? what, we just dont know until you say.
Jan 10, 2014 | 2007 Suzuki Grand Vitara 4WD
I have a 2002 1.6 Suzuki Grand Vitara which jumps out of 4 wheel drive on occasion, is this a common fault and is it an easy fix? Also I need to locate the ERG valve. Thanks Wildpunto
My 1999 GV has the same problem. From my initial research, it seems that a common problem is a faulty air pump or a leak in the air line or actuator that engages the 4wd. This vehicle uses a pressure line instead of a vacuum line to engage the 4wd. I just got my GV back from my mechanic about 30 minutes ago and it seems like my air pump is dying (mounted inside the front bumper). Now I just have to find a replacement. ( I live about 90 miles from the nearest dealer.)
Jan 06, 2010 | 2002 Suzuki Grand Vitara
Above speed of 80 km/h slight vibration can be felt and continues
if you google "grand vitara vibration" you will find a discussion board about the many many grand vitaras getting around with a vibration problem. I happen to be one of these people and am seriously thinking of selling the car after all the problems I have. It appears to be a drive train design fault which will cost a fortune to fix, believe me its not a tyre problem, ive had 4 wheel alignlents and balances and it never seems to fix the problem.Take it to a mechanic and let them have a good look at it.
Aug 12, 2009 | 2007 Suzuki Grand Vitara 4WD
4WD not working properly
this is most commonly caused by the motor on the transfer case that engages the 4X4 either sticking or defective, sticking can be caused by dirty fluid, have u ever serviced the fluid in the transfer case, it should be done around 30,000 miles if u use the 4X4 allot.
Dec 12, 2008 | 2000 Suzuki Grand Vitara
PIAA 2006 Suzuki Grand Vitara - All Grand Vitara models - Xtreme White Bulbs Logo
298 people viewed this question
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
