Question about Measuring Tools & Sensors
Is the outdoor sensor replaceable? - Measuring Tools & Sensors
  • 739 Answers
Short answer: Yes
long answer: is it worth the replacement costs of a single component as compared to replacing the system
Posted on Apr 03, 2015
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Replace outdoor sensor
The outdoor sensor is located in the control box are or just below it and is connected to the control board. The repair usually means changing the board and the sensor as they come in a kit. It will also include a thermistor for the coil temp, if this is a heatpump
Feb 23, 2015 | Heating & Cooling
Malfunction display saying outdoor sensors. Everything checked out fine with the unit and the display board, so the problem is with the communication between them. Any answers?
Usually an outdoor sensor is a thermistor. You need to check the resistance range on the thermistor to see if its withing specs. If it isn't you will get an outdoor sensor error.
In all likely hood the sensor needs to be replaced.
Oct 05, 2014 | Carrier Heating & Cooling
My indoor/outdoor temperature unit no longer will display outdoor temperatures
have you let the sensor synch while it was inside near the base unit after changing the batteries? lithium batteries work best in the cold
Aug 06, 2017 | Heating & Cooling
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Reset air temperature sensor on 2002 bravada
Instructions
Shut off the engine of your Bravada, remove the keys from the ignition, and open the hood.
Locate the plug that powers the outdoor sensor. You will find it in between the front bumper and frame of the car, just to the right of the rightmost support bracket. The sensor plug is green.
Unplug the outdoor temperature sensor by separating the plug from its socket.
Plug the sensor back in, close the hood, and start the car. If the sensor's performance has not changed, it will need to be replaced.
Read more : http://www.ehow.com/how_7982496_reset-bravada-outdoor-temperature-sensor.html
May 22, 2012 | 2002 Oldsmobile Bravada
PANASONIC CASSETTE AIRCONDITIONING ERROR CODE NO :- F27-02
f27- indoor outdoor unit disconnected. Check the power output of indoor and input of outdoor.
If no power you have to check indoor room temp sensor through which thermostat send command to outdoor unit. If your sensor is good, you have to repair/replace your PCB
Dec 14, 2010 | Heating & Cooling
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Measuring Tools & Sensors Logo
325 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
