Question about Hyundai 2011 Equus Signature
How do I remove a Hyundai Equus OEM hood emblem
Why is Hyundai Equus very difficult to control when driving on snow or ice?
loss of traction control--normal when the ice condition is encountered
change tires to snow tires or use chains
Aug 19, 2016 | Hyundai Cars & Trucks
Remove emblem
Look for a retainer at the back of the emblem. If it has one, remove it. It the emblem is attached with adhesive use the appropriate tool to careful pry it off.
May 21, 2014 | Vehicle Parts & Accessories
How to remove hood emblem
underneath the hood were the emblem is there should be a spring lock or fasteners you can undo
Apr 21, 2014 | 2007 Mercedes-Benz CLS500
Need emblems for 97 toyota celica
Try toyota collector's website and source out spdcific needs
Mar 09, 2014 | Decals, Emblems, & Detailing for Toyota...
2011 equss sunroof inop all fuses are good ????
2011 Equus is still under warranty. Take it to the nearest Hyundai Service Department & have it diagnosed & repaired under warranty.
Aug 31, 2011 | 2011 Hyundai Equus
I want to remove the leper on the hood. Is there
As far as I know 2007 and 2008 US Jaguars don´t have the leper jag on the hood, instead, they have a Jaguar round emblem, ask a Jag dealer. or maybe the round center emblem of the wheels can fit there. Good Luck
Jul 19, 2010 | 2002 Jaguar X-Type
How to replace 2004 bmw z4 hood emblem
if it's regular emblem , then it has two plastic pins on the sides (Left and right , very tight fit), it's almost impossible to pull emblem out without braken it.
hood has two plastic clips ,were those pins go.
Apr 18, 2010 | 2004 BMW Z4
Nissan Xterra SE 2004 - Front Hood Emblem Removal...?
Think it got two pins held by plastic grommets
May 12, 2009 | 2002 Nissan Xterra
Where are the spark plugs on a 2009 hyundai accent located ?
You have to remove the oil filler cap and then remove the fancy black plastic cover which is labeled "DOHC 16V" and which has the Hyundai emblem on it.
Apr 12, 2009 | 2007 Hyundai Accent GS Hatchback
Hood emblem installation
Just put the replacement hood ornament in the hole and use a pair of pliers to pull down and turn the lock 1/4 turn clockwise. It is spring loaded and if you look real close at the ornament you will see what piece to pull down and turn. Right now it is locked in its shipping spot.
Jul 30, 2008 | 1989 Mercedes-Benz 300-Class
Hyundai 2011 Equus Signature Logo
57 people viewed this question
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Jerry Kramer
Jerry Kramer
tony wahlman
tony wahlman
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
