When I put a cd in my onn portable player it says disc and will no run. ?
SOURCE: GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Posted on Nov 18, 2008
leecom72
  • 4806 Answers
SOURCE: portable dvd player keeps saying bad disc
try cleaning the lens with a lens cleaner cd, if this doesn't work the lens itself is scratched or faulty and you will need to buy another dvd player
Posted on Nov 27, 2008
petraman7
  • 1175 Answers
SOURCE: my portable dvd player shows no disc when i put my dvd in player
Hi....
Very lightly clean the laser lens ( looks like a very small eyepiece)
with 91% or better alcohol on a swab. Then very lightly dry it off.
Also..have you tried another DVD or CD in it?
Check for dust or debris in where the laser pickup is
Posted on Feb 25, 2009
localwonder
  • 6784 Answers
SOURCE: Plays CD but not DVD, says no disc
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Posted on Aug 13, 2009
ejkudelka
  • 1188 Answers
SOURCE: polaroid portable DVD player error code ''bad disc''
You'd need to open the unit, and the problem is either that the laser and the tray are misaligned, which can be tricky to fix even, or worse, you need a new laser. Either way, the Polaroid dvd player may not be worth getting repaired if it is no longer under warranty.
Good luck!!
Posted on Nov 29, 2009
How do I get the CD player to play on on portable player
Most likely the player is played out. Time for a new system.
Feb 24, 2017 | The Audio Players & Recorders
What kind of accessories can I get for an ONN portable CD player?
Portable CD players typically have only a charging port and an audio, so the only "accessories" would be a charger (uses a mini-usb end) and either headphones/earbud or an external speaker. You can use a wireless Bluetooth speaker if you purchase a Bluetooth transmitter: Google (link to search for same)
Mar 24, 2016 | Televison & Video
I have a onn dvd portable my daughter gave me while i was in hospital but it says no disc but the disc is in the dvd
This sounds like your player doesn't recognize the disc's format. You can either try the disc in a different player or try different discs in your player.
When your known good player shows "no disc" it means either the player has a problem recognizing the disc's format, or the disc is bad or maybe the lens has gotten dirty.
Nov 08, 2014 | Televison & Video
When I install disk, ' No disk' shows on display.
IS the disc on a CD-R or CD-RW (burnt disc) some portable players will not support those types of disc's.
It could also be a different region dvd that doesnt match the region codes of the dvd player. There are no known region hacks for your make and model of dvd player.
Sorry and thank you for choosing Fixya! Post back with more info for further help.
May 18, 2009 | Durabrand 8.5'' Portable DVD Player
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
My portable dvd player shows no disc when i put my dvd in player
Hi....
Feb 25, 2009 | Initial IDM-1731 Portable DVD Player with...
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
No disc
check ur cd/dvd into other drive if it reads properly then there is the problem dvd player, try cleaning the lens
if it does not work take to service center
Nov 23, 2008 | Curtis DVD8017 Portable DVD Player
Portable cd player
since its portable the lens may be dirty, try rubbing acl with cue tip. if doesnt work the lens could possibly be damaged
Sep 24, 2008 | Memorex MVD2042 DVD Player
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
