Question about Compaq Computers & Internet
Why does a compaq mini laptop not have a RAM(Random Access Memory)
  • 739 Answers
It does have RAM, just not upgradable. To use a typical slot for RAM chip sets would make the unit larger.
Posted on Apr 03, 2015
Why does a compaq mini laptop not have a RAMRandom Access Memory
Obviously it does have RAM. Sometimes the ram is placed on the motherboard and is not upgradable, as using a typical ram chip set and the corresponding slot would necessitate a larger unit.
Apr 02, 2015 | Compaq Computers & Internet
Ram is almost full on my 530 need to know how to increase it or erase it?
RAM is random Access memory if it is too full then you need to shut off some programs and use them one at a time or find older copies of the programs your running which do not take so much space.
Oct 27, 2014 | Computers & Internet
What is ram
RAM-Random Access Memory
RAM is an acronym for random access memory, a type of computer memory that can be accessed randomly; that is, any byte of memory can be accessed without touching the preceding bytes. RAM is the most common type of memory found in computers and other devices, such as printers.
http://www.webopedia.com/TERM/R/RAM.html
Apr 24, 2014 | HP Pavilion dv9000z Notebook
What is the use of RAM?
The ram is basically the speed memory, any programs open are saved to the ram while in use, the more ram the more things can run. Hope this helps :)
Jun 06, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I need to know what RAM I should use in my Compaq Presario 5000 desktop computer
You have three Ram Memory slots.
EACH ram memory slot's maximum amount is 256MB
Total Maximum Amount for the computer is 768MB.
Uses SDR Sdram ram memory.
[Single Data Rate Sdram. Commonly just referred to as Sdram.
That is a misnomer.
All ram memory from SDR to DDR3 IS Sdram.
Synchronous Dynamic Random Access Memory.
SDR Sdram = Single Data Rate Sdram
DDR Sdram = Double Data Rate Sdram
DDR2 Sdram = Double Data Rate 2 Sdram
DDR3 Sdram = Double Data Rate 3 Sdram
Just thought i would share ]
Uses SDR Sdram that operates at a frequency rate of 133MegaHertz. (133MHz)
Also known as PC133.
Make sure it is,
A) Non-Buffered
B) Non-ECC
C) Low density
D) CAS Latency of 3 (CL3)
E) Uses 3.3 Volts
Here's an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=423457&CatId=828
One more,
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146303
For questions post in a Comment.
Regards,
joecoolvette
Dec 08, 2010 | Compaq Presario 5000 PC Desktop
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
Compaq evo d51s beeps on boot
Try to reseat the memory sticks. Sometimes they just need reseated.
Oct 25, 2009 | Compaq Evo D500 PC Desktop
Location of memory slots
Hi.There are a set of instructions that we need to follow for the upgrade process.You can increase the amount of RAM (random access memory) in the notebook with an optional memory module approved by Compaq.The notebook contains 2 memory slots, one of which is accessible for an optional memory module upgrade.Please refer to think link and select the Hardware Upgrade option in the list in the file which will guide you thru picturised views for helping in the memory upgrade.Link is : http://h10032.www1.hp.com/ctg/Manual/c00090108.pdf.
Please let us know whether this help or whether you need more help
Mar 16, 2009 | Compaq Presario R3000 Notebook
Diff between SDRAM and DDRAM
Only one of those will work in any computer. Synchronous Dynamic Random Access Memory is older and slower, Double Density Random Access Memory is faster and DDR2 is newer. The notch in the connector edge will not match the RAM slot if you have the wrong one. Also the DDRAM has various speeds to match the bus speed of the motherboard so designators like PC2100, PC2700, PC3200, etc. are important and correspond to 266MHZ, 366MHZ, 400MHZ, and so on. Notebook use SODIMM RAM and have the corresponding DDR, DDR2 designators but still have notches that must match the slot. When you buy RAM just provide the model of your computer as each manufacturer has numbers that are all designed to confuse it seems and there may be no chance of exchanging the memory after you open the package. Steve
Oct 14, 2008 | Compaq Presario 700 470024-192 Notebook
Installing 1GB Memory
the problem is will your processor read 1GB of random acess memory. install you open the laptop remove the screws and access the mother board push down the usually white clips and lift the ram straight out, when installing make sure you ease the stick into the socket and when you have it against the bottom push it firmly until the clips lock back into place.
Dec 09, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
