In the Temperature display I only see "- - - -" not the temperature. What could be the problem? Thanks
  • 739 Answers
Typically this is a user issue, as in not reading the manual for instructions.
This is typified by not including make and model of the unit in question, not relaying information such as if the batteries in the remote are new or need replacement, etc.
I suggest reading the operator's manual, particularly the troubleshooting section, for information regarding your issue.
If you have no manual, then contact the manufacturer and get one.
Posted on Apr 03, 2015
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
How do I change the temp fro m degrees C to degrees F? I have a Accubake System single oven. Thanks!
From Page 15 of the Manual:
Press and hold the "Custom Broil" pad for 5
seconds. A short tone will sound
NOTE: The temperature display will go off
and the temperatures displayed will
after a conversion. The temperature display
be converted. To switch back to "F, repeat the instructions above.
NOTE: The temperature display will go off after a conversion.The temperature display will reappear the next time you press a cook function command pad.
Jul 16, 2011 | Whirlpool RBS275PD Electric Single Oven
Flashing temperature control for freezer setting
There is no problem for that, as long as the temperature control is functioning well and it display the temperature degrees number. You vary it, hi or low and the unit still cold or freezing.
Sometimes the liquid crystal display of the electronic control module become loosen 'cause it to display in a flash manner. Unless it display "ER" it means there's something wrong with your unit. But so far it operate normally.
Thanks for asking.
Jul 04, 2011 | Refrigerators
I sthere a way to calibrate my oven temperature? It is off by about 35 degrees. Temperature is lower than display.
Sorry to read about your problem, I hope this helps you out.
To Adjust the Oven Temperature (do not use Bake or Broil while adjusting the oven temperature): note: Your oven control was factory set in the (Fahrenheit) °F Temperature Display Mode. To change for (Celsius) °C, see page 15.
1. Press & hold the BAKE key pad and release after the display shows the factory temperature setting of 00. note: If the oven temperature has been previously adjusted from the factory setting, the current temperature adjusted value will appear in the display instead.
2. You may increase the oven temperature in 5°F (1°C) increments with each press of the uP arroW pad to a maximum oven adjustment of +35°F (+18°C). You may also adjust the oven temperature downward in 5°F (1°C) increments with each press of the doWn arroW pad (total range of -35°F to +35°F (-18°C to +18°C).
3. If you do not want to keep the display adjustment, press the clear oFF pad before the oven control beeps. This will cancel the temperature adjustment procedure. To start this procedure over again begin with step 1 above OR;
4. If you want to keep the adjustment, wait until the oven control beeps once.
5. The oven temperature adjustment has be accepted by the oven control and the display will return to the time of day.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire FEB24S2AB Single Oven
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
The interior rear view mirror has temperature and compass displays, but only work for a short time at start- up.I have tried unplugging the harness on the back of the mirror and cleaning contacts. It`s...
Temperature Display
The inside rearview mirror supplies a 5 volt signal circuit and low reference circuit to the ambient air temperature sensor. The inside rearview mirror monitors and records the voltage on the signal circuit of the ambient air temperature sensor. The inside rearview mirror uses this recorded voltage to display the temperature on the temperature display portion of the compass/temperature display. The temperature display will show "ICE" when the ignition is first turned on and the current temperature is 3°C (37°F) or below. The display will toggle between "ICE" and the actual outside temperature for approximately 4 minutes.
The mirror will display "OC" if the mirror senses a temperature of less than -40°C (-40°F).
the mirror will display a "SC" if the mirror senses a temperature of greater than 112°C (143°F).
Replace the inside rearview mirror with compass. Refer to Inside Rearview Mirror Replacement .
Nov 14, 2017 | 2001 Chevrolet Suburban
Outside temperature display (next to a/c display?)
The ambient air temperature sensor at the fron of the car has gone bad, a new one can be obtained from any GM dealer.
Aug 03, 2009 | 1992 Oldsmobile Cutlass Supreme
Outside temperature
The exterior temperature display is built into the Automatic temperature control unit. or the A/C controls. Look at the buttons for the A/C unit and press the one that is marked "EXT". This will display the outside temperature.
May 15, 2008 | 2006 Lincoln Mkx
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
