Question about Weedeater Garden
Weedeater gbi 22 leaf blower will not start, how do I start it and what could be the cause?
How do I do a tuneup?
  • Eugene Rounds Apr 03, 2015
    There is a whole host things can cause 2 cycle not to start. You will go through a check list of things eliminate those that the pass the tests.
    First will it start if you add a little fuel mix through the carburetor throat? If just runs a second or two will eliminate a lot things.
  • 739 Answers
Replace the spark plug, drain last years fuel and use fresh fuel mix.
Sounds like you may have a fouled plug. A speck of carbon or other debris can short the gap causing ZERO runtime.
Posted on Apr 03, 2015
Hello i'am working on a poulan pro weedeater pp330 i need the adjustment on the air and gas mixture screws
it would be only on the fuel side--adjust all closed then open half way--this should allow to start then adjust to best idle
Sep 05, 2014 | Poulan Pro Weedeater Leaf Blower/vac...
Have Homelite Yard Broom II UT08514. Fuel filter fell out of tank when I dumped old gas! Which little black tube (way back in the tank) does it belong on and how do I reconnect it? thanks
I have a GBI 22"v leaf blower anyway i replace a pull cord on blower but dosen't pull cusae it hard to pull i took everything apart again and again and still hard to pull the cord ok help me pelase.
Dec 18, 2011 | Garden
Weedeater blower GBI-22v starts then shuts off already cleaned carb,replaced fuel and filter and cleaned plug
see if it will run with the choke on, if so then looks like the carb needs new diaphram and needle
Sep 27, 2011 | Garden
I have an weedeater 22"
check the fuel
if old -- TOSS it OUT!
Fuel quality sucks and has ethanol,. which eats rubber hoses and leaves residues through the carburetor and more,. try wiggling the needle valve without turning it - if otherwise do not loose placement of where the needle valve is setting currently if you do turn or remove the needle valve for inspection..
Also try some starting fluid to blast it a bit,. be careful if it is 2 cycle as you need oil to run the engine too!
Best regards
ck
Aug 18, 2011 | Garden
What is the gas and oil ratio for Weed Eater leaf Blower GBI 22V? please
40:1 which is 3oz. of 2 Cycle Oil to 1 Gallon of gas.
Jim
Aug 15, 2011 | Weedeater Gas Blower
Weedeater gbi 20 leaf blower will not start, how do I start it and what could be the cause?
Start procedure is, switch igbition on, lever to full choke, pull until it fires once, do not continue pulling with full choke, move choke to central position, crank engine until it runs, once warm move choke to off, if it refuses to start, drain the fuel tank and re fill with fresh mix, remove spark plug and check for a spark by earthing the plug against the cylinder, if after many pulls the spark plug is dry, there is a blockage in the carb, remove the air filter cover, remove the two allen screws holding the carb on, remove the single screw securing the alloy pump cover, under the diaphram is a filter, replace this filter, rebuild and try again.
Apr 23, 2011 | Garden
My weedeater 150 mph starts hard and barely runs at full throttle. I put in new gas, plug, and clean air filter. Please help. John
One cause of such a symptom could be an obstructed exhaust. Make sure the outlet of the muffler is not obstructed (ex. dirt dobber nest), also check the exhaust port by removing the muffler.
Feb 16, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I have poulan/weedeater leaf blower
ignition coil,or blown head gasket...
Nov 08, 2009 | Poulan Garden
GBI 20 Weed Eater Blower ran out of gas and will not restart What to do to restart?
somewhere on it is a primer button pump it a few times and choke the blower it should start
Sep 18, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
342 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Jerry Kramer
Jerry Kramer
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
