Question about Option Computers & Internet
How to setup huawei hg533 router
Can connect to internet but ip camera working one day then lost the next.ip changes on pc's whenever re booted.correction for this is difficult as wlan lan & wan configuration is badly explained with jargon,plus an option 60 which i cannot get info on.
  • Anonymous Apr 02, 2015
    firmware V1.15t f1.01
SOURCE: Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Posted on Nov 20, 2008
  • 53 Answers
SOURCE: 3CRWER100-75 no DHCP IP on child routers
router 1 (base) router 2 (repeater) router 1 (base) is the network, the SSID is where u get your internet connection set router 2 with same SSID, DHCP on. i advise connecting hardline to make sure both routers are working correctly. once thats verified then go wifi
Posted on Feb 04, 2009
jsbasrao
  • 54 Answers
SOURCE: TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Posted on Mar 20, 2009
Sutibun
  • 186 Answers
SOURCE: Problem with RV042 linksys router
Ah Wan 2 doesnt like to receive a DHCP address you will have to get static Ip addresses
Posted on Aug 21, 2009
jhoeldorz
  • 169 Answers
SOURCE: No internet on PC when cables going through router
Hello there,
You have to start from the beginning and my solution would be:
1) Remove any connections(also don't forget to turn of wifi on your laptop) to router and except the power cord. With the unit powered ON locate the reset pinhole on the back of router.
2) Press and hold reset button for at least 15 secs. then release, wait for 20-30 secs. before the router can completely rebooted.
3) Configure your Computer IP address to “Obtain an IP address automatically” .
4) Connect internet cable to router on port labeled "WAN". Connect PC to any LAN ports available.
5) Now lets configure wireless router. Open any browser you have (IE, Firefox, Chrome, Safari, etc.). On the address bar type: "192.168.1.1" (without quotes). Default username: admin ; default password: admin click "OK".
6) Go through "SETUP WIZARD" until you reach the "Setup WAN Interface" page. On "WAN Access Type:" select "DHCP" then click next.
7) You may configure your "Basic Wireless Settings" to Public or Private until finished configuring.
8) On "Operation Mode" be sure you operate on "Gateway" mode.
That's it! Hope this helps.
Don't forget to vote.
Posted on Mar 12, 2010
How to configure huawei hg533 router for home network
William the more information you can provide the more accurate can be our brain trust community's answer.
What I have to guess is you added the cameras to an existing network.
What you need to provide is how are the camera's getting their IP addresses ?
How are the PC getting their IP addresses.
My guess
Go into the router settings and look for DCHP server. Look at the leases issued and change the IP addresses that are assigned to the cameras to Static rather than Dynamic. if the cameras are getting IP address from DHCP. server rather than being set up manually..
If you manually set up the IP addresses on the cameras then alter the available ip range on the DHCP server to avoid the IP addresses assigned to the cameras. As an example say the DCHP range was 192.168.1.1 to 192.168.1.254 then alter it to be 192.168.1.21 to 192.168.1.254 and then hence the ip addresses 192.168.1.2 to 192.168.1.20 are used on static ip addresses like printers and cameras devices.
How do you log into the router
go to the internet browser and type in 192.168.1.1 and it should bring up your router The user name is most likely admin and the password will be admin by default. If no one has changed them.
I have looked at the usre manual but it does not spell out how to change the DCHP ip address ranges leases out or the way to change the ip addresses leased out to static for the cameras. I think you will find some sort of setting in thew dhcp menu option of the router.
What
I think is happening is called an ip address conflict. And the above suggestions should stop this from occurring when you reboot the IP address is re assigned and the DCHP server could be issuing ip address leases to your p.cs that are already staticly assigned to your cameras.
Apr 03, 2015 | Computers & Internet
Is the HG533 router an 802.11ac
www.chatteris.biz/.../HUAWEI_HG533_User_Manual(02,English,General_... specifications go to the above address to download the manual including tech specs
Nov 22, 2014 | Computers & Internet
Come across a really annoying problem within our household. We're with TalkTalk for internet, i'm on a PC connected via WiFi through a dongle on the network. There's also a TV that is causing the...
Ok. (I don't know how much help I can offer since I'm in USA and you're in UK). 1) From what little I was able to look up, TalkTalk Internet is really small and has a lot of issues regarding on what it delivers to it's customers. 2) The HUAWEI HG533 Router... (from your description of the symptoms with your TV), seems functioning ok, just that the Bandwidth (Internet speed of your ISP-TalkTalk) is too slow to keep up with everything you want to do once you add the Video for the TV. IF you use the Internet cable from your router to the TV, you should have a Faster connection for internet reception (compared to WiFi. Minimum of N-Band on WiFi should suffice for 1 TV and 1 Computer. 5 Devices or more, I recommend a Better Router and Cable your Devices that need the Fastest connection for response, IE. 1-2 computers, TV or Blu-Ray device that provides content to your TV). Best advice - Inquire your Internet Provider about your situation, Possibly change ISP's, Make sure your Router can handle the Usage on WiFi and Cable connect that you require. I have been using a D-Link DIR-655 N-Band Gaming Router (broadcasts WiFI @ 65Mbps/sec, 4 cable connect Ports with 1Gbps speed) for several years now. I've got 2 puters and a Blu-Ray device cable connected, we WiFi our 3Cell phones, a Sony WII and 2 other puters for our kids. We pay a about $25 more a month for faster Internet speed, all runs rather well (Time Warner Cable Turbo, USA, total Internet cost is $65 a month, we don't subscribe to any tv or land-line phone, since we use cell phones).
Jun 20, 2014 | Computers & Internet
Huawei HG533 router
OK, do you have a question?
Mar 05, 2013 | Computers & Internet
Lost my IP address from zyxel
According to me there are two reason for not connecting to internet through your ISP.
1. Configuration setup might have got deleted
2. Driver files may be corrupted
An important thing to know is We would not lose our IP address.
Static IP address wouldn't be changed while restarting our modem,
Dynamic IP address changes on every restart of our modem. To know the Current IP address the following URL will be useful to you. http://www.ip-details.com/
Jul 25, 2012 | Zyxel P-2602HW Router (P2602HW)
Buffalo router setup
You have to change the DNS servers on your PC's internet connection.
Instead of using DHCP, type in the two IP addresses from your account at dydns.com.. Right click on your connection icon and choose, "properties".. In the panel presented, choose Internet Protocol (TCP/IP) the last item in the panel. Next click 'properties' and remove the dot from "obtain IP automatically". Next, type in your new DNS server IP's. The top panel is for you PC address which has to be between 192.168.1.2 and 192.168.1.224. It doesn't matter what IP you choose as long as it is not an address used by another device). The subnet mask will fill itself in. Default gateway is 192.168.1.1. In the bottom panel fill in your new IP's. That's it.
Apr 13, 2010 | Buffalo Technology AirStation Nfiniti...
Hello there,
Mar 12, 2010 | Encore ENHWI-G2 Router
How to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Mar 02, 2008 | Computers & Internet
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
67 people viewed this question
Top Option Computers & Internet Experts
D. E. Hev
Steven Conroy
Steven Conroy
Are you an Option Computer and Internet Expert? Answer questions, earn points and help others
