My remote works all functions on my TV except Volume UP or DOWN.... The Volume buttons on the TV & Channel UP do NOT work either...... Any suggestions people?????
    Problem Solver:
  • 9 Answers
Call the company brand of the television and get a new remote.....or use cable remote thats programed to tv
Posted on Apr 03, 2015
  • 1,205 Answers
Good afternoon
Agree with the above. Do you use cables like HDMI or scart? If you do check if they are in the correct place.
then open menu and go to sound and see if something is amiss there.
enjoy your coffee
kolbrun
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
satavlad
  • 405 Answers
SOURCE: no input selection availiable on sharp aquos lcd tv
You have to come back to EZ SETUP and complete the setup procedure. Press MENU>SETUP>EZ SETUP.
Posted on Dec 29, 2009
Controls not working onDaytek TV, 40 in LCD,
yes, look carefully in the manual as I think it has a lock out feature that will lock out both keyboard on set and remote except for on off features.
Jun 13, 2012 | Televison & Video
Buttons stopped working
If there is a tv button on the remote, try pressing that..
Chances are its damaged and you might need to order a new one from Hitachi or possibly use a universal.. With remotes there really isnt much you can do when they stop functioning.
Jul 17, 2008 | Hitachi VT-RM391A Remote Control
I have a Humax LU23 TD2 television and have now got Sky tv. I would like to know how to use the Sky remote to control all the functions such as power on, volume etc. for the tv. Can you help...
Hello
These are the setup processes for Sky TV.
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 28, 2011 | Televison & Video
Sony KV-32FS12. Buttons on the TV don't work, the remote don't work. Now stuck in one channel. Can access Menu with TV button but can't go anywhere. Unplugged from main power source still no go. Tried...
Hello
Your TVs front control buttons are inoperative except menu button. There are microswiches fitted inside the main board of your tv from which shafts ar extented towars the front of the cabin where you press to access the functions. Replace all the micro swiches inside at onetime. It won't cost more. Micro swiches as they have said is mini swiches, which can get damaged easly with high pressure thumb or impact put on it.
Oct 15, 2010 | Sony KV-32FS12 32" TV
Volume and channel up/down keys remote probs
The remote's broken.Find the replacement of the remote with same type, or
if you want to do it yourself, open the remote case, then try cleaning all the rubber pad and the button pad inside the remote using alcohol, this should works.
Mar 07, 2010 | Toshiba CN36V51 TV
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Jun 06, 2009 | Panasonic TH-42PX60U Television
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
Mar 13, 2008 | RCA RCR460 Remote Control
TV will not turn off and TV buttons preform the wrong functions
check D1004 5v zener diode, if defective it can cause you this type of problem, also check D1003 and D1005.
part # 8-719-929-15 from sony.
these diodes are located in HS board, the one where all your front button are located in. by the way the HS board is no longer availableffrom sony
Dec 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
