Question about Swisher 52" 20 Hp Riding Lawnmower #Zt2052
Remove rear tires scag walk behind - Swisher 52" 20 Hp Riding Lawnmower #Zt2052
My scag 48 inch walk belt driven ,is having trouble going up slight hills , already change the clutch springs
I also have a 48" Skag wall behind mower. Have you checked the tension on each wheel's belt when under load? It that where the slippage is, or is there a slow down on the engine itself? If the engine is slowing down...several things to check...needs tune up...plugs...I also use premium gas in my mowers and get better performance. Check all belts for where and slippage. Is it engine or some mech connection?
Hope this helps
Paul
Jun 10, 2017 | Garden
My 48" scag walk behind will stall out if the (deadman) handles are not held down
Sounds about right or else that is just what is suppose to happen. It is a safety so the mower doesn't run over the operator if something happens.
Apr 22, 2017 | Garden
I have a scag walk behind and the left tire stopped engaging. Do you know how to fix?
if not a simple cable adjustment
or drive shaft isn't broken between gearbox and wheel
will have to inspect the internals of the gearbox
this is close to the walk behind gearbox
How to take apart and reassemble Peerless 700 ind-vdftmprayiwrzc40uomd3tff-1-0.jpg
Apr 07, 2017 | Garden
How do I change tire of Toro Proline 44?
the fronts on these walk behinds are solid , i replaced one of mine with a scoffold caster that i had worked great , the rears are tube'd tires , you can get the tube replaced with out even taking tire off the machine , jack up side that your working on , let all the air out of tube (remove valve core ) i use a old hvac vac pump to suck every last bit of air from tube , break tire bead seal , push with piece of wood !! after you get entire bead down , work tube from around the bead seal to you get it all out , push stem down hole then its out , reverse to reinstall new tube any lawn shop sells them inthat size , add air to new tube till beads seals , then let it out to correct pressure (i use 12 psi) let jack down and off you go !!
Sep 30, 2014 | Garden
My scag walk behind will not move in reverse
if its hydro drive check the linkage adjustment if its belt drive they never worked very well you need to push down on the handles to help it tighten the belt
May 21, 2012 | Garden
Remove rack & pinion-05 cts
Is it allwheel drive or rear wheel drive ? makes a difference where rack is mounted. If I remember right rear whl drive rack is mounted behind frt tires and awd is in frt of tires.
Jan 31, 2012 | Cars & Trucks
It road walks from side to side like the front end is loose. Have checked the steering gear box and tie rod ends and neither are loose.
make sure it is tracking right that is that the back tires are straight behind front tires try turning front wheels straight and get a string put it on the side of front tire and run it back to the rear tire string should be straight if not then the tracking is off
May 24, 2010 | 2002 Jeep Grand Cherokee
Swisher 52" 20 Hp Riding Lawnmower #Zt2052 Logo
195 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
