Question about Garden
Removal of ear tire - Garden
    Top Expert:
  • Garden Master
  • 44,268 Answers
Some have a c clip or snap ring that needs removed first then wheel will slide off
Posted on Apr 02, 2015
Im swimming every day ,what can I put into my ears to stop wax build up
!st of all if you are swimming everyday then you shouldn't have wax buildup. That's one of the problems with swimming a lot, the water and chlorine get into your ears and remove all the oils, that's why swimmers get (swimmers Ears). Now if you've just started swimming and water is getting trapped in your ears then you can go to the store and buy some Debrox ear wax remover ora lot of people just take regular old peroxide and put 2 or 3 drops in their ears and let it go to work. 2 or 3 drops every day and in a week or so your ears should be cleared out. The just a drop every couple of days to maintain it.
Oct 28, 2013 | Tyealg39 Ears Giraffe Ears Green Ball...
New rotor, pads & bearing left side wheel makes humming sound from there at high speed 65 +
I would have bet money on the wheel bearing but since you replaced it and its still there guess that rules that out. So try rotating the left tire to a different position on the truck. You may have a tire that is out of round or cupped or seperated tread. I know that seems stupid but it will rule out the tire. What would really be useful is a set of chassis ears. This a tool that utilizes headphones and a series of clamps that you can clip onto different parts of the car. Using this you can hone in on exactly where the noise is coming from. Might be available to rent from some parts chain stores.
I recently drove a pick up that I would swear had a rear axle bearing going out on it. As it turned out it was a front wheel bearing. I say this because noises can sound completly different when your driving than from what they really are. You may have a right side bearing problem? Chassis ears would definatly be a big help. Good luck!
Feb 09, 2011 | 1999 Ford Explorer
VW 2004 V-6 Touareg: I have un-indentified grinding, shimming in my front end. It's not bad tires, out of balance tires nor engine related. At 2000 RPM/50-65 mph a thumping noise, even in neutral, more...
Find a shop with a 'rolling road' or 'electric chassis ears'.
Chassis ears are microphones you place under or around the car and drive it listening to each microphone to locate the noise.
Rolling road you can listen whilst going nowhere.
Sound like you have a collapsed engine mount allowing engine to rub somewhere.
Shop search near you : http://www.iatn.net/shopfinder/
Jan 16, 2011 | 2004 Volkswagen Touareg
Front end grind
Sounds like a wheel bearing.
Feb 20, 2010 | 1995 Toyota 4Runner
2000 Honda Accord - very loud road noise
caster,camber and, wheel bearings
have your car 4 wheel aligned this will adjust your rear caster and, camber.
have your wheel bearings checked
Sep 06, 2009 | 2006 Toyota Camry
Hmming
This Started after the Tires were installed Correct???? If so, It is the New Tires. They will do this for a While at first.
Jan 21, 2009 | 2005 Nissan Maxima
Two-Way Radio LI 5650 WXC -> ear bud doesn't work
Did you try plugging in the audio device before turning on the radio? If so, follow this by pressing the PTT on the radio once. It should clear the problem.
Dec 07, 2008 | Radio Communications
Ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
Nov 12, 2008 | Sony MDR-V6 Professional Headphones
How to replace brakes
  1. Remove the cover on the master cylinder and siphon enough fluid out of the reservoirs to bring the level to 2/3 full. This step prevents spilling fluid when the piston is pushed back.
  2. Raise and support the vehicle. Remove the front wheels and tires.
  3. Push the brake piston back into its bore using a C-clamp to pull the caliper outward.
  4. Unfasten the brake hose fitting from the caliper using a flare nut wrench, cap the fitting to prevent foreign material from entering the or the hose.
  5. Remove the two bolts which hold the caliper and then lift the caliper off the disc.
  1. Remove the inboard and outboard shoe.
If the pads are to be reinstalled, mark them inside and outside.
  1. Remove the pad support spring from the piston.
  2. Remove the two sleeves from the inside ears of the caliper and the 4 rubber bushings from the grooves in the caliper ears.
  3. Remove the caliper.
  4. Check the inside of the caliper for fluid leakage; if so, the caliper should be overhauled.
To install:
  1. Lubricate the sleeves, rubber bushings, bushing grooves, and the end of the mounting bolts using silicone lubricant.
  2. Install new bushing in the caliper ears along with new sleeves. The sleeve should be replaced so that the end toward the shoe is flush with the machined surface of the ear.
  3. Install the brake pads.
  4. With the two pads in position, place the caliper over the brake disc and align the holes in the caliper with those of the mounting bracket.
  1. Fill the cavity between the bolt bushings with silicone grease. Install the mounting bracket bolts through the sleeves in the inboard caliper ears and through the mounting bracket, making sure that the ends of the bolts pass under the retaining ears on the inboard pad.
For best results, always use new bushings, sleeves and bolt boots.
  1. Tighten the mounting bolts to 35 ft. lbs. (47 Nm) for R/V Series; 28 ft. lbs. (38 Nm) for 1988-92 C/K Series and 38 ft. lbs. (51 Nm) for 1993-98 C/K Series.
  2. Connect the brake hose to the caliper and tighten the fitting until the are snug.
  3. Pump the brake pedal to seat the pad against the rotor. Don't do this unless both calipers are in place. Use a pair of channel lock pliers to bend over the upper ears of the outer pad so it isn't loose.
After tightening the mounting bolts, there must be clearance between the caliper and knuckle at both the upper and lower edge. On R/V Series, the clearance must be 0.010-0.024 in. (0.26-0.60mm); on C/K Series, it must be 0.005-0.012 in. (0.13-0.30mm) for 1988-91, and 0.010-0.028 in. (0.26-0.71mm) on 1992-98 models. If not, loosen the bolts and reposition the caliper.
  1. Install the front wheel and lower the truck.
  2. Add fluid to the master cylinder reservoirs so that they are 1/4 in. (6mm) from the top.
  3. Bleed the brake system.
  4. Check the fluid level again and add fluid as necessary. Do not move the vehicle until a hard pedal is obtained.
Jul 04, 2008 | 1995 GMC Yukon
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
