Something is causing my laptop to stall
I am asking you to find the problem & fix it
    Habit-Forming:
    Scholar:
  • 74 Answers
Also, please provide some more information.
What are the computer specs?
What things are you trying to do?
Is it unusually hot?
There are tons of factors that can cause a computer to stall. Without more information it is literally impossible to provide a solution.
Thanks!
Posted on Apr 02, 2015
    Top Expert:
  • Computers & ... Master
  • 52,086 Answers
Not knowing the make or model you ask too much we are good but not wizards
2000 jeep grand cherokee with 4.7 l shuts off while driving replaced throttle control sensor and crank sensor.
You need to check and see what fault codes are in memory, there will be something there.
Nov 04, 2016 | Jeep Cars & Trucks
1997 geo metro stalls while driving
ok, it stalls., are you asking for a guess? as to why?
why is it stalling? there are 50 causes. and about 5ways (classes)
So you want wild guessing> or some tests. gueSS/tests?
  1. never tuned up this decade , tops the list. CLASSICAL.
  2. engine low compression. ever change the cam timing belt ever?
  3. too much fueling, ,flooding and gross misfire. and stalls.
  4. too little fueling, lean starvation and stalls.
  5. EGR stuck open.
there are simple tests, and cheap tools to do it, in each case.
ask.
Sep 09, 2014 | 1997 Geo Metro
Why does car shut off and checking light randomly blinks
Check engine light or MIL (Malfunction Indicator Light) comes on when there is something wrong with the engine's injection system or when the car stalled. Get it scanned for Error Code and fix the error, usually engine sensors. Electrical connectors to the sensors coming loose would give the same problem.
Jun 11, 2014 | 1992 Toyota Corolla
2004 Chevy Malibu keeps stalling
Throttle cable is probably not the issue at all. I would bet this is the fuel relay. It is in different spots on every vehicle but it is about a 60 to 100 dollar part and very easy to replace once you find its location.
Feb 12, 2014 | Cars & Trucks
How do i stall a stator on a suzuki 2001 tl 1000r
without the specialty tools for the job. you'll never get it apart with out damaging something..so take some good advice and have a trained tech fix it for you..cause after you spend the money and time tracking down all tools needed its probably going to cost you more. Are you sure the stators bad? Has it been tested? Have you tested your loom for shorts? Have you ruled out every other possibility? just asking good luck. I would check the whole starting system before spending any money on unnecessary parts because most electrical parts are non returnable and quite costly..
Aug 23, 2012 | 2000 Suzuki TL 1000 R
My 2001 honda cbr600 went into the garage last week as it kept stalling the mechanic said it was the valves and charged me 600 pound for the trouble of changinf them i was reassured it would be fine two...
Maybe, (getting ripped off), try gettting a second opinion. If the engine is not smoking or knocking real loud, it is probably something else causing the stalling issue.
Nov 17, 2010 | 2001 Honda CBR 600 F(4)i Rossi
Van stalls while driving, just some times. no problem code comes up.you can be driving and times it will stall but it starts back up!! you never know when it will stall. had it in the shop and they say it...
I had a 2006 that did that and it turned out to be the intake manifold gasket had failed. Something for the shop to fix if you aren't super handy.
That may not be the cause and a shop should diagnose it before you assume that the manifold is the cause.
May 29, 2010 | Dodge Caravan Cars & Trucks
HP Officejet 9120 not printing. Getting the following message: Printer Error. Paper Stall. Paper Motor has stalled. There are no paper jams. Fax is working OK.
this is happening cause your printer carriage is out of time! and if your not familiar in how to basically rebuild printers this is best left to a professional that works on only printers there is really no easy fix
Jan 14, 2010 | Computers & Internet
When starting the car it kinda stalls
Could be as something as simple as a plugged fuel filter to spark plugs to a sensor going bad. Could also just be a bad tank of gas. You could try running some fuel injection cleaner in the gas tank and maybe replace the fuel filter. Also clean or replace you air filter. And the spark plug electrodes might be worn out and need replacement. Just trying to give you some simple maintenence ideas that do not break the bank and may fix your problem. There are many variables that can cause stalling. You might need to have a mechanic hook it up to a diagnostic computer and start the car. When it is stalling they will be able to see exactly what the cause for the stalling is and fix it.
Nov 05, 2009 | 2004 Chevrolet Aveo
96 Buick Century stalls....
I spent endless time on this same problem on my 1992 Wagon. I changed out the computer but no help. It turned out to be the top dead center crank sensor that tells the system when the crank passes TDC. It is a small magnet essentially about the siz of a pencil eraser in the flywheel. it was cracked and occasionally would not "sense" and the car would just quit. troubleshooting was a nightmare because the computer diagnostics on the 1992 are less capable than the 1996 model. Anyway that is a relatively inexpensive fix and easy to know if it worked. Let me know how you solve this.
LT
Jul 08, 2009 | 1996 Buick Century
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
