Question about Uniden DECT 6.0 Cordless Phone ID
How do I enable phone-to-phone intercom? - Uniden DECT 6.0 Cordless Phone ID
How to use Alexa as intercom between rooms
It has a feature called "drop in" once enabled (settings in the Alexa app) you just say "Alexa, drop in on aaa" where aaa is the name of another Echo or Dot. Both must be in your contact list (which you create after enabling the feature). You can also say, "Alexa, call yyyy" where yyyy is any other person in your contact list. Unlike Drop in, Calls must be answered...just like a phone instead of an intercom.
Dec 26, 2017 | Computers & Internet
Radio shack intercom 43-493
Do you by chance have a DSS cordless phone that is interfering? Normally these should work well up to over a hundred feet for sure. Try swapping channels on the intercom units and keep away from metal (Like a refrigerator) and motors.
Mar 06, 2018 | Radio Shack This easy-to-use intercom...
Hot to use intercom between handsets and how to expand handsets ?
There is a service called the push to talk service. Which is not exactly the same as the intercom but will do the task of a normal intercom easily (But with slight difference). You can connect to different mobile phones at a time. To use this service just simply ask your service provider to enable the service for your device..
PLEASE RATE THIS ANSWER, IF YOU GET ANY HELP FROM THIS ANSWER, OR IF YOU LIKE THE ANSWER.
Apr 04, 2011 | Uniden Cell Phones
How to use the intercom system
  • Check your telephone to see if it has an intercom feature. Many wireless phones that come with multiple units allow you to temporarily turn one unit into an intercom to contact other units attached to the same wireless phone system. Depending on the model, you can contact all the other phones at once, or a single specific phone, by pushing the intercom button and entering the other mode. To put the phone back into regular mode, all you have to do is switch off the intercom option.
  • Contact your telephone provider. Some telephone service providers allow landline phones to call themselves, which enables the phone to function as an improvised intercom. You would simply pick up the phone, dial and then close the connection. Once the phone is answered elsewhere in the house, you will have established a line to another phone and you can speak normally on it. This has largely been eliminated due to lack of need as technology advances, but it may still be an option with some providers.
  • Purchase and install an intercom system that will work through an existing phone line. Many of these products, some of which are produced by Panasonic, operate as a halfway point between a traditional intercom system and a phone line. The exterior intercom links directly to the phone line, and you can pick up the phone and talk through the intercom unit outside once the system is properly set up
  • Dec 18, 2010 | Uniden Cordless Phone
    Phone not ringing
    This feature has to be enabled on extension 10 or 11
    Press Feature 00, left intercom, left intercom, right intercom
    enter your extension number
    press line button until it is in the solid state and display say immidiate.
    Press Feature 00 to exit programming.
    Cheers
    Jul 09, 2009 | AT&T Lucent MLS-12D Phone
    How do I retrieve messages on the Panasonic KX-T7030 phone?
    • Call into your mailbox (usually by dialing intercom 165)
    • Press 4, and 4 again (for "Incomplete call handling")
      By default, three options are enabled:
      option #1: leave a message
      options #5: call the operator
      option #6: return to top menu
    • Follow the audible prompts to disable options 5 and 6
    Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Intercom pages coming through phone speakers HELP!
    Try 325. Not sure if your system admin necessarily wants this feature turned off though. In my case we don't have an overhead speaker for dedicated paging so we programmed all handsets to page through the phone speakers. Your system admin probably has your phone in a page zone if the 325 shortcut works so you might want to ask before your turn it off.
    j
    Dec 13, 2008 | Inter-Tel Axxess Corded Phone
    Caller i d
    Hello matsikw,
    It is either calls through your intercom as you suspected, or AT&T might have enabled the feature then realized it should not be on. It is one or the other.
    Kay
    Jackson Communications
    Aug 02, 2008 | Uniden TRU 448 Cordless Phone (TRU448)
    Uniden DECT 6.0 Cordless Phone ID Logo
    54 people viewed this question
    Top Uniden Lands Phones Experts
    k24674
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
