Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
How do I set up phone-to-phone intercom? - Uniden DECT 6.0 Cordless Telephone Expansion Handset
  • 774 Answers
There is no special set-up required. The phones should be compatible with one another; i.e., designed to work together. There is a small button on either phone that establishes the intercom link when pressed. Look at the instruction and they will show you which button to press. It's easy, you can even find it by trial and error quick enough.
Posted on Apr 02, 2015
Intercom uniden D1688
After reading the manual over and over with no success, I got the hint to successfully do an intercom call by reading a post from a website.. The manual says to press the Intercom buttom. Then select the phone you wish to intercom with (or All phones) - do this by using the up-down button. The step left out of the manual is: THEN press the MENU key. It works perfectly!!
Jan 07, 2012 | Uniden Cordless Phone
How to use the intercom system
  • Check your telephone to see if it has an intercom feature. Many wireless phones that come with multiple units allow you to temporarily turn one unit into an intercom to contact other units attached to the same wireless phone system. Depending on the model, you can contact all the other phones at once, or a single specific phone, by pushing the intercom button and entering the other mode. To put the phone back into regular mode, all you have to do is switch off the intercom option.
  • Contact your telephone provider. Some telephone service providers allow landline phones to call themselves, which enables the phone to function as an improvised intercom. You would simply pick up the phone, dial and then close the connection. Once the phone is answered elsewhere in the house, you will have established a line to another phone and you can speak normally on it. This has largely been eliminated due to lack of need as technology advances, but it may still be an option with some providers.
  • Purchase and install an intercom system that will work through an existing phone line. Many of these products, some of which are produced by Panasonic, operate as a halfway point between a traditional intercom system and a phone line. The exterior intercom links directly to the phone line, and you can pick up the phone and talk through the intercom unit outside once the system is properly set up
  • Dec 18, 2010 | Uniden Cordless Phone
    HOW TO SET INTERCOM
    What do you mean, "Set Intercom"? Program someones intercom on your button?
    Feature00
    press the button you want to program
    press the LEFT intercom button and the 2 digit extension number
    feature00
    Feb 25, 2010 | Avaya Eurostyle 18D Corded Phone
    Is there a way to intercom directly onto the speaker ???
    you should have 2 intercom buttons on your set, an SA ring and an SA voice. The SA voice (or voice intercom) should be the second from the bottom.
    Sep 16, 2009 | Avaya MLX 5D Corded Phone
    Set time and date toshiba dkt2010-s
    DK Programming
    From Reception phone only
    --(time set)DK- intercom #652 HH mm SECs redial
    --(date Change)- intercom #651 yy mm dd redial
    CTX Programming
    --(time set)ctx-intercom #652 HH MM SEcs #
    --(date change)-intercom #651 YY MM DD #
    Jan 10, 2009 | Toshiba DKT2010SD Phone
    To set time and date on toshiba
    What Toshiba system do you have?
    CTX Programming
    DK Programming
    PLEASE, PLEASE try and help me...I can't tell you how much this would be appreciated. I have a Panasonic KTS4100 4 line phone (2 corded phones in our office, and one cordless). I have NO IDEA how to use...
    Just in case you missed the manual:
    http://www.centralcomms.co.nz/pdf/KX-T2375-brosh.pdf
    There are 2 conditions you need to be aware of
    1 No DSL on the line
    2. Set the intercom extension of the second phone
    By default, both have been assigned ext 11. The intercom uses the same frequencies as a DSL line to transmit, so that could be the noise you are hearing.
    Page 23 tells you how to set the intercom extension, and the DSL warning is almost at the bottom of every page from 18-22.
    Carl
    Nov 25, 2008 | Lands Phones
    Intercom
    I do not have any information on your specific phone but I'd like to try and help. Typically a multi-line phone set up like this would need a way to intercom between phones. I have not seen one that can utilize the same wires as the phone service but I also have not looked. It would also need each phone to have it's own identification (extension assignment). You only need two wires for each phone line but for intercom there most likely needs to be another pair of wires connecting all the phones together. I hope you have a manual. Look carefully at the section dealing with wiring up the phones to the phone lines. It should mention intercom at some point and what is required. Also, you can have up to 16 phones. Each phone must have a setting to choose a number between 1-16 or maybe 10-25, 100-115. By default these will all be at the same setting and you would not be able to intercom.
    Jul 23, 2007 | RCA 25414RE3 Corded Phone
    Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
    51 people viewed this question
    Top Uniden Lands Phones Experts
    k24674
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
