Question about Harrington & Richardson H&R Sportster in 22 Win. Mag Single Shot Rifle Sights Blued Barrel & S
I don't know anything about the gun it was given to me without the cylinder .I would like to know how old it was and what it shoots. all I have is the serial number it is A16809
  • 38 Answers
Go to there website:
hr1871.com/
or look up Harrington & Richardson on the web.
Posted on Apr 02, 2015
    Scholar:
  • 98 Answers
Here is a link that answers all your questions. Sportster 8482 Sportster Compact Sportster 17 HMR
Hopkins and allen gun #654
https://en.wikipedia.org/wiki/Hopkins_%26_Allen
Some were in a "break open" configuration and some were in single action type.
They are old and I wouldn't try and shoot it; before a certain year only black powder is to be used and F modern powder is use gun would explode. Take it to a reputable gunsmith and have them look at it and give you an appraisal on it.
Oct 03, 2015 | Miscellaneous
F28WW-fire gun. piston doesn't retract back, trigger is good gun is clean & oiled what could be the problem. nailer year old
Check band # 175520 (black rubber band around the outside of the cylinder) is what causes the piston to retract. If the check band is in place, then problem could be caused by cracked lower bumper, worn piston oring or cylinder seal on the headvalve. IF the cylinder seal is bad, air will leak between seal and the top of the cylinder and could push piston down cylinder. If piston oring is too loose, the piston will not stay at the top of the cylinder. If you point the nose of the gun up then down again and the driver moves within the cylinder, replace the oring. Good luck
Apr 04, 2013 | Stanley Bostitch Stick Framing Nailer...
Air blowing out exhaust nonstop gun won't shoot
Replace the O rings... sounds like its one in the firing valve ( rear cap of the gun behind the cylinder )
Nov 19, 2012 | Tradesman Air Tools & Compressors
Why does my roofing nail gun jamming, it would fire one nail and the hammer will remain out, so i toke a screw driver and push the hammer back in, and it still did the same thing
Simple test for piston jam. With nails removed and latch open, point nose of gun up then down. If the driver slides up and down in the cylinder as you move the gun, replace the piston oring (test gun for proper operation). If the piston stays in the upper most position as you move gun (push driver to top position), check lower bumper and bottom seal under the bumper (sheet). Replace as needed. If the lower parts are in good condition (good piston oring, lower bumper and sheet) , replace the 3 orings on the feeder piston. Good luck
Dec 03, 2011 | Hitachi NV45AB2S Coil Roofing Nailer
I have a d51822 framing nailer that will shoot a nail but then not recoil to shoot the next nail, if you wait 10-20 seconds the gun will release air at the top of the gun and recoil
Most likely there is a problem with swollen orings between the cylinder and cylinder spacer (white plastic piece between cylinder and body ). Order the oring kit because nost likely when you take the gun apart the orings will fall apart. Dewalt used vinyl orings instead of viton on critical areas of the cylinder and these vinyl orings failed.
Sep 21, 2011 | Dewalt Clipped Head Framing Nailer
Don't know how to load the nails in the gun
There are two ways dependent upon the gun model. Pull the charging handle back and insert the nail clip with the forward facing, leading edge POINT in first. Some guns allow you to put the nail clip(RACK) in the gun then pull back on the charging handle. BOOM your ready to shoot.
May 28, 2011 | Tools & Hardware - Others
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Porter cable roofing gun
The problem that you describe could be caused by three things. First remove the cylinder and look for a black rubber band around the cylinder about med section. There is an indention with holes where it is supposed to be. The band should fit snuggly so that it does not slip off during use. Secondly, check that the piston oring/plastic ring holds the piston in the cylinder without just dropping under its own weight. Third, the upper bumper could have a crack or missing piece. Remove it and check. (vinyl part in headvalve) Parts are available at dewalt repair center or www.toolpartsdirect.com. enjoy
Dec 06, 2008 | Porter Cable Cable RN175AR Reconditioned...
Bostich gun problem
If the piston/driver is broken, the gun will fire however nailing will not take place because the piston will jam in the cylinder. Sometimes the cylinder will also crack when the driver goes. If the piston is not broken but stays down, then check the cylinder check valve, worn lower bumper, bent driver or cracked cylinder. 18 guage nailer has a very thin driver which will easily bend or break. Parts however are not expensive.
Nov 18, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Harrington & Richardson H&R Sportster in 22 Win. Mag Single Shot Rifle Sights Blued Barrel & S Logo
167 people viewed this question
Top Harrington & Richardson Optics Experts
james laughton
james laughton
ray gallant
Are you a Harrington & Richardson Optic Expert? Answer questions, earn points and help others
