Question about Maax Home
How do I turn on my whirlpool bathtub after installations
Is Aveeno Colloidal Oatmeal Treatment safe for this American Standard Installed Whirlpool Bathtub?
Hi Virginia,
I've done some research on tubs with jets, and from what I've read I wouldn't put anything granular in the water.
The granules may damage your pump and also when the water stops some granules will be left in the pipes, where they will decompose and turn into.... well, I don't think it'll be nice.
Nov 24, 2015 | Whirlpool Home
Jets won't turn off. Pushing the button does nothing. We have to unplug it (inside skirt) to shut off jets
New? Who installed? If installer, call him back. If you did it, you missed some control wiring from main box to the controls outside or someone shorted you on some critical control parts. If you aren't sure what your doing via the owner's manual, you need a good technician. Water and Electricity don't mix and can be dangerous!.
Feb 27, 2015 | Kohler K-1224-LA-0 Mariposa 5.5 whirlpool...
Will it be a big job to get a Sterling bathtub installed in my house?
Installing a new bathtub can be a bigjob and you should get professional advice and shop around for quotes. Thislink gives good tips about home installation: http://www.house-improvements.com/how-to-install-a-bathtub
Jul 15, 2012 | Sterling 60"L x 42"W Almond Tub...
In line heater will not light up when turn on
You will need to check where it is installed and compare that to the model number of the heater. A vacuum heater must be installed in front of the pump on the suction line coming from the suction cover inside the bathtub. If you have a WOW pump then that style of heater will not work in the suction line because the pump doesn't have enough '****' to operate the vacuum switch.
A pressure heater is installed in the pvc piping after the discharge of the pump. anywhere in that line before a the jets.
Jan 03, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
The jet in my jetted bathtub only works for a second then turns off on its own, while the motor is on. its brand new and just installed it.
sounds air bound,....turn the others off while leaving the air bound one open, this should force the air out,....don't run it to long without working right (not good for motor),..good luck, cracklin joe
Jan 05, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
We just moved into a house with a whirlpool bathtub. When I turn the bubbles on in the whirlpool, the jet streams out so hard that it shoots water all over the bathroom. Am I doing something wrong when I...
the bathtub needs to be full.  and you can turn the jets on some modles.  old homeowner new this and probably turned the jets up so it will do that not really funny.
Jun 25, 2009 | Home
On/off switch on new tub install stuck in the on position; pushed until it turned off, but now it won't turn on
Order a new switch from the manufacturer, cut of the main power from the circuit box, and remove the old switch.
The new one should fit right in and the wires clip on.
Apr 27, 2009 | Whirlpool Hydrosystems 72 X 36 Biscuit ...
Bathtub whirlpool leaks. problem is that the tub
Stop leak in a bottle absolutely does not work, look closely there should be some sort of access panel (maybe well hidden) to get under there.
Mar 24, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Feb 22, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Installing an Aqualux (Desiree) whirlpool bathtub
call the manufacturer Asteria Bath Company at1-800-288-4002 and they can send it to your email address.
Nov 02, 2008 | Home
Home Logo
193 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
