Question about Refrigerators
I have twist air fridge.2001 model ccr12ffw and serial number va130778 Two tecnitian said freezer fan motor not work. But don't found it. It is
  • Refrigerators Master
  • 5,323 Answers
Its located behind the freezer wall in back usually?
Posted on Apr 04, 2015
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
Sea Breeze
  • 4655 Answers
SOURCE: fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Posted on Mar 29, 2009
carputers
  • 255 Answers
SOURCE: whirlpool fridge serial numberEH1228713 model
replace the defrost timmer pcb
Posted on Sep 07, 2009
diodeic
  • 1622 Answers
SOURCE: I have a whirlpool top freezer refrigerator
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired togather . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Good luck in solving the problem.......
Posted on Aug 15, 2010
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
I have a dometic rv fridge, the freezer works not the fridge
you have to send the brand name and model number so i can help you.all that happens is the evapcoil in the freezer gets cold,the evap fan motor blows cold air from the freezer into the fridge side,depending on your model you could have a bad damper,this is a door that is in the fridge section,it opens and closes letting the air come in,try this,open the freezer door,if you don't hear the fan blowing you could have a bad fan motor,also touch your hand on the back inside wall of the freezer,if you have frost or like ice on the back wall you have a defrost problem,ice is biulding up on the coil and the fan can't blow the air over to the other side..if you need more help,do these tests and send the model number off of the machine and brand name,side by side or freezer on bottom,open the fridge door,look up on right hand side wall near ceiling or on ceiling,freezer on top look on left side in fridge section.
Jul 12, 2012 | Dometic Refrigerators
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
Refrigerator not cooling. doesn't seem like fan is blowing. freezer still working
all that happens is the cold air from the freezer gets blown into the fridge section by the evap fan motor brhind the inside back wall of the freezer so if you open the freezer door and don't hear the fan blowing i would say that yes you do have a bad evap fan motor and that's why the fridge section is warm.next time send the brand name and model number so i can help you better
Sep 17, 2011 | Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
What should I check if the refrigerator is not cooling/working, but the freezer works fine?
first off what kind of frige and model number,the freezer feeds the fridge so no cold air is being blown into the fridge section from the freezer,open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor,put your hand on the back wall of the freezer,if there's ice or like snow on it you have a defrost problem,bad defrost thermostat,heater,timer or board depending on the machine,this is why i need the model number,also on some machines there is a damper that opens and closes to let the cold air into fridge section or the door was left open and the air vents are froze up,most common on bottom mount freezers,look at the freezer ceiling and packages,if you see frozen water droplets on the ceiling or packages it's a sure sign the door was left open.hope this helps.
May 03, 2011 | Refrigerators
My refrigerator side is not maintaining a cool temperature, and the green temperature light is off (the freezer side works fine)
the problem is in the freezer side,all it does is blow clod air from the freezer to the fridge side so if the fridge is warm the freezer side is either iced up or the fan isn't blowing,open the freezer door,do you hear the fan blowing,if not you could have a bad evap fan motor,also check the back inside wall of the freezer,you might have to pull the second from the bottom bin out and touch the wall and see if it's iced up or if there's frost on it,if so you have a defrost problem,let me know what you find and send the model number ,open the fridge door,on the right side up near the ceiling you'll see a tag with the model and serial number,i just need the model number and i'll be glad to help you
Oct 31, 2010 | Kenmore 57066 Side by Side Refrigerator
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
