Question about Eaton Powerware 9390 UPS System
Is the configuration error alarm can block the unit to run? how to clear that alarm?
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
How to reset configuration error of the UPS 9390?
This error can only be cleared by the Eaton technician with their laptops. If this is a new unit it HAS to be factory started or your warranty will be void.
Apr 02, 2015 | Powerware 9390 UPS System
Reset the alarm light on a hoover nextra frost free
na
you need to full defrost it doors open for a few days
this melts the ice monster behind the freezer compartment
you can access it from inside the compartment from a few screew
whats happened is the drain holes to the evaporator are blocked
so it will never go frost free
because the blast chiller section
where the fan is at the back on the freezer compartment isnt running and its drain hole is also blocked
you can use a pipe cleaner brush or something
and dress it will salt
youll find a tube goes from inside the chiller to the same evaporator tray usualy set above the compressor as its source of heat
so once you clear the tubes check the fan
clear the ice monster
check for any rubbish down the back of the unit
and clear it away
also the unit should be atleast 4" from the wall and with good ventilation
now fully clean turn it on close the door
wait twenty mins
open the freezer you should get rolling vapors from it
and you should also hear the fan running quietly
give this a try....
Dec 08, 2014 | Hoover Washing Machines
Freezer alarm
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Sep 06, 2013 | Electrolux Freezers
Verifone vx670 security alarm
Verifone units has multiple sensors built inside for security reason. If you acceidentally dropped or jarred the unit, the sensors will kicked-in and give that error that you have now. And i'm also thinking about your internal system battery is getting low too and needs to be replaced. Then we need to reload the Verifone Tamper Removal Software to clear the Tamper error. Tamper error can be cleared, if you still need help you can call us @ (775) 358-2922 ask for Randy. Hope to hear from you. thank you.
Jun 23, 2012 | VeriFone Vx 670 Payment Terminal
Service indication blinking on information panel. Unit is working fine. What does this indicate and what should I do?
1.Press Colder Key Once
2.Press Alarm Key Once
3. Press Colder Key Once
4. Press Alarm Key Once
5. Press Colder Key Once and Clear Error History Yes? Should Appear
6. Press Alarm Key Once all Error codes will clear including "Service"
Sep 16, 2011 | Sub-Zero 632 / S
Have Liebert DH125 down flow unit with one (1) alarm
ive worked on many liebert units therss a water sensor on the bottom of the unit basicly the units pan try to find that switch and mayb cleen under it or if it s aprob depinding on the age
Apr 08, 2010 | Heating & Cooling
Paper jam alarm in, but there is no jam.
try to reset the printer or turn it off for 1min and then back on. That should work.
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Eaton Powerware 9390 UPS System Logo
149 people viewed this question
Top Eaton Computers & Internet Experts
Lawrence Oravetz
pawnpower
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
