What should temp split be for a mini split unit
    Scholar:
    New Friend:
  • 128 Answers
What ever you are comfortable with. Just keep in mind that the further away from the ambient temperature, the more power you will use and the higher the running costs. 24 - 26c is considered optimal.
Posted on Apr 02, 2015
2 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Conair mini split heat pump isn't cooling but has cold suction line but warm liquid line and is not freezing up the evaporator. Thinking a sucking reversing valve?? What could cause that? Both evapor
Make sure that your refrigerant charge is good first. Reversing valve has 4 pipes coming off of it. The one alone is discharge and centre of 3 is suction always. The two sides are the reversing pipes. One side should be same temp as discharge and other same temp (+-5F) as suction. If not then you have bypassing refrigerant in valve. Bad.
Jul 13, 2013 | Heating & Cooling
The unit after running for ten minutes blows hot air inside the house
Service your unit completely and then check the following. 1. Thermostat setting must be minimum +3 degree from your temp. 2. Check room temp sensor 3. Check your out door unit fan motor. (If the outdoor fan runs with less rpm the compressor will get cut off by overload protector)
Dec 13, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have a 18000btu LG mini split heat pump installed about 1 year ago in vacation home. In heat mode the unit cycles on and off when room temp is within 2-3 degrees of set point. Cycle on time varies...
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Oct 26, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
