Question about HP DeskJet Office Equipment & Supplies
How to hook up to cromebook os - DeskJet HP Office Equipment & Supplies
When i try to download the canon print app onto this cromebook. it tells me the app is already downloaded and which device do i want to use it with . only the cromebook isnt an option
There are some gaming companies which have made a lot of progress in gaming and have contributed a lot in taking gaming to another level. EA games are one of those computer games manufacturers. This company is especially known for its apkpure.to of sports. The most interesting Anger Of Stick games that you play daily are made by the people of this company.
https://apkpure.to/download-tiny-gladiators-apk/
Jan 23, 2018 | Canon Office Equipment & Supplies
Cromebook will not take charge..may be charge port..do you have an authorized repair service in or near Delaware Ohio
SORRY but FIXYA has no repair shops any place in the world . check with where you bought it
Sep 25, 2017 | In Office Equipment & Supplies
How can i restore it with out itunes
Open settings
  1. Select General
  2. Scroll down to reset
  3. Select reset all content and settings
  4. Select erase iPhone
  5. Confirm
Restore and iPhone without iTunes
Aug 25, 2015 | Apple iPhone 5S
How to open facebook on cromebook
hi
i am not particularly familiar with the chromebook os, but the web browser is certainly going to e google chrome. load google chrome and in the address bar type "www.facebook.com" (without the inverted commas) and ta/press return. this will take you to facebook.
it is also possible that there is an icon on the desktop which would take you straight there by double tapping on it.
hope this is helpful, if so would you please register that with fixya
cheers
Jan 21, 2015 | Computers & Internet
Samsung cromebook no sound; tried powerwash, etc. no positive results
Enter its sound menu, and check whether audio is muted or not. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Dec 21, 2014 | Samsung Televison & Video
Had cromebook 3 weeks got on internet once and can't get on again
Open System 'Settings' with the menu button then 'Wi Fi', and see if have an internet connection available. If yes, select it, if not select 'scan' (making sure your modem is powered on and connected). You should then be prompted for a password - and hopefully it'll work.
Hope this helped.
Jul 25, 2014 | Acer C720 Chromebook Gray 11.6" Notebook...
Acer how to setup
Hello. This may help. Your Wireless Network name and SSID are one in the same. Lot's of people will customize there wireless network name (SSID) like "smithfamily". However, if it wasn.t customized the default SSID should be used. This can be found on the sticker on your modem. Now then, as you know, when you try to connect to your network you are prompted to provide a network Key or PASSPHRASE. The same applies here as above, if it was customized then the Key or PASSPHRASE will be different then the default Key or Passphrase found on your router.--So when it say's you have a "badphrase", your Key or PASSPHRASE is incorrect.. Good Luck
Feb 10, 2014 | Computers & Internet
Sir, Good day! How to reformat my hardrive toshiba dynabook without dvd drive
You'll need to remove your hard drive, hook it up to another computer via a USB to Hard Drive adapter and use the operating system of the other computer to reformat the hard drive. This will only reformat the hard drive, not install a new OS. To install a new OS you'll need a DVD-ROM and OS installation disc, or a flash drive with an OS installer on it to install from the flash drive.
Mar 25, 2010 | Computers & Internet
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
