Question about Microwave Ovens
So if there is an insect inside the board area and you don't feel comfortable disabiling the microwave its safe to say its trashed and throw it away?
  • Microwave Ovens Master
  • 3,368 Answers
Unplug it, have dinner then remove the cover and use a vacuum nozzle suck out the bug, much cheaper then replacement. If you mess it up then do plan one and get a new one.
Posted on Apr 02, 2015
Microwave not working
Click on How a microwave works
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Apr 09, 2013 | Microwave Ovens
Microwave not powering up
Jan 24, 2013 | Microwave Ovens
What does L mean on the display?
Jan 21, 2013 | Maytag Microwave Ovens
Samsung Microwave Mdl# MW6470W Just keeps flashing
Dec 24, 2011 | Samsung MW6470W/MW6471G Microwave Oven
Magic chef 990W microwave clock keeps resetting. What is wrong and how can I fix?
Make sure that the program controller is receiving power - step down supply. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Since the clock is resetting it is a fault on the main board and the processor as it is tripping. So check power, check for faults mentioned above on the board. Also if there is fault of the magnettron leak or a waveguide leak then clean and check insulation.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
Thank You for using FIXYA.
Sep 23, 2011 | Magic Chef MCD990W Microwave Oven
Kenmore microwave won't work. Has F9 message.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Sep 14, 2011 | Microwave Ovens
Has power but it does not heat up food items
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had depositedthen it must be checked or replaced.
Sep 03, 2011 | Whirlpool GH5176XPS Microwave Oven
The microwave oven comes on and everything works correctly but does not get hot. Cannot find fuses anywhere or how to get inside.
Aug 11, 2011 | Whirlpool WMH1162XVS Microwave Oven
Microwave Oven is not heating
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean , solder and reset the board.
Aug 02, 2011 | LG Microwave Ovens
Light comes on, turntable working but no heat (microwave)
Jul 27, 2011 | LG Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
