Question about Power Computers & Internet
Last night there was no power and the UPS went off, now I am not able to turn On UPS, all battery breaker tripped and I cannot make them On , and the machine is not starting
  • 156 Answers
If the UPS is more than 5 years old, the batteries are likely dead and must be replaced.
Posted on Apr 02, 2015
Electric range breaker trips at night when all asleep, resets ok
Are you sure nothing else is using power? Sounds like a ground fault to me. Any devices which could cause harmonics which you can think of?
Feb 14, 2013 | Computers & Internet
Power went out in house last night. Now the fan
First check where the fan draws power from.
A light switch? Is it on?
Blown fuse, tripped breaker?
Oct 30, 2009 | Hunter Designer's Choice 5-Switchblades Lg...
200AMP Breaker trips same time every night
Something doesn't sound right here. You indicate 2 200Amp breakers. With a single service entering the house, this is not possible. The "sub-panel" to the pool house is more likely a 100Amp setup, yes? If not, you have a bad setup and it should be corrected. I would suspect that you are attempting to pull too much current to the pool and that is what is tripping the breaker. Also, these breakers should not be run over about 80% of their capacity for the long haul. If they are, they tend to age and get either real sensitive causing tripping when it shouldn't or you can run 500Amps through it and it won't trip.
My suggestion is to revisit the setup. If the pool house is fed from the main panel, make sure that the breaker for it is not 200Amp. Second, try disabling the pool house breaker to see if that is the source of the problem and look more closely there.
Keep us posted.
Dan
Jun 29, 2009 | Electrical Supplies
Burnt out
internal failure possibly on power side, lower than 300A fault current so unit could not trip i/p protection and as fault was post ac section, continued to burn internally.
it just broke
no breakers tripped out so it kept drawing current until the fault burnt away.
maybe this is what happened, need to know a lot more info to change hypothisis
Jun 01, 2009 | Vector VEC056D 2500 Watt Power Inverter...
APC ES-350 won't turn on; all I see is a blinking light.
Try looking for a small circuit breaker on the side that says "press to reset" - you could have tripped it accidentally when you unplugged the iPod.  Also, try pressing and holding the UPS power switch for 10-15 seconds.  That should force a power on as well.
May 27, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
UPS shuts down when the mains is off.
Hi
After 3 years, i would by a new UPS...
The battery will have to be changed if you want to keep the old one.
What i've seen mostly here in south africa. When the battery life has ended they customer opens the ups and takes out the battery and then connects a car battery to the terminals. The then close the ups and let the car battery stand outside the ups.
Hope this info helps...
Apr 26, 2009 | Powercom BNT-600AP (bnt600ap) UPS System
Mge galaxy 20kva ups input breaker trip
Does it trip immediately or after a time? If it's immediate then there's a dead short on the line (or possibly inside the UPS). If it takes time to trip then there's a slow build up of too much current use. This is usually caused by defective capacitors in a power supply.
Apr 06, 2009 | MGE UPS Galaxy 3000 UPS System
Powercom BNT 1500AP quit working after power outage
From your description it appears one or more batteries are bad..The circuit breaker on the Power Strip..which more then likely is a 15 Amp..tripped due to over current conditions..check the batteries and reset the circuit breaker..That should take care of it
Dec 28, 2008 | Powercom (BNT-1500AP) UPS System
LCD shows Low O/P V
Fault: Low Ouput Voltage
Cause: Surge Taken by load / Short Circuit on load / Fault in inverter
Remedy: Remove load and restart UPS / Try a different load / Repair or swap out
If you need spares or price for repair contact Eaton Power Quality Ltd - the new name for Powerware - 01753 608700
Dec 15, 2008 | Powerware 9120 UPS System
Computers & Internet Logo
184 people viewed this question
Top Power Computers & Internet Experts
john smith
Sattech
Level 1 Expert
MonsterByte
Level 1 Expert
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
