Question about Sharp EL-2615G Calculator
How do I set for the points $10.60 for example
    Genius:
  • 1,167 Answers
I cant activate my MMS
Title: MMS settings
For Hotlink GPRS Activation
Press *133# to activate your Gprs & MMS
For the setting
1. SMS "GPRS "BRAND" "MODEL" and sent to 22333 example "gprs nokia n70"
2. SMS "MMS "BRAND" "MODEL" and sent to 22333 example "mms nokia n70"
Manual WAP Settings
? On Desk, tab Control Panel -> Internet setup. (or similar)
? Tab New access pt. and tab No, then tab Next and key in the following:
Connection name: Maxis GPRS / Maxis 3G
Data bearer: GPRS
? Tab Next
Network type: IPv4
Auto-retrieve access point: (Unchecked)
Access point: net / unet
? Tab Next and key in the following.
Prompt password at every login: (Unchecked)
Username: maxis
Password: wap
? Tab Next then tab Finish and OK to complete the setup.
? Homepage: http://wap.maxis.com.my/wml/index.wml
? Session Mode: Permanent
? IP adress: 202.075.133.049
? Login Type: Automatic,
? Authentication Type: Normal
MMS Settings
May 12, 2011 | Computers & Internet
Tip
Editing DNS Records with GoDaddy For Your Kajabi Account
Note: GoDaddy is used as an example how to edit DNS Records because their user interface is easy to work with. As each provider has a different way of doing this, you may need to contact their support center specially if you are not comfortable editing DNS Records. Just show this article to them and they should be able to figure it out.<br /><br />Before anything else...<br /> <ul> <li>A Host Record is used to map the domain name to the IP address of the host that serves your website.</li> <li>CNAME Record is an alias of another address (www.example.com is an alias of example.kajabi.com).</li></ul>Let us continue...<br />For using a Custom Domain name with your Kajabi account, only two steps are needed for this to work.<br /> <ul> <li>Step 1: On your end (this is done at your domain provider/registrar). (3) A Host Records that points to our IP addresses (75.101.145.87, 75.101.163.44 and 174.129.212.2) and (1) CNAME Record for 'www' that points to your Kajabi site (example.kajabi.com) must be created. Details found here.</li> <li>Step 2: On our end configuration is automatic after adding your domain (www.example.com) in the Custom Domain field under the Project Settings tab.</li></ul><br /><utube src="oIUZY67iv-Q"><br /><br />Wait! I already have an existing site.<br /><br />The following guide below is provided for those who ONLY want to add their Kajabi site as a Sub-Domain to an existing site.<br /><br /> <ul> <li>Step 1: On your end (this is done at your domain provider/registrar). Create a CNAME Record (ex: 'members', 'portal', etc.) and point it to your Kajabi site (example.kajabi.com). Details found here.</li> <li>Step 2: On our end configuration is automatic after adding your domain (members.example.com) in the Custom Domain field under the Project Settings tab.</li></ul><br /><utube src="0V7G4UBq0yA">
on Mar 22, 2011 | Computers & Internet
I can't find ip adress (192.168.0.50) because i'm not sure to proceed factory reset on DAP-1353
The device communicates with the computer devices least displaying details. For example, setting up the router modems requires connections also from where the computer adminstrator sets the passes least disclosing detail IP addresses.
Apr 04, 2011 | D-Link DAP-1353 Wireless N 802.11n...
How can i know the APN access point of my nokia 2700 classic?
ACCESS POINT NAME IS NOT PHONE SPECIFIC IT IS OPERATOR SPECIFIC. DIFFERENT OPERATOR USE DIFFERENT ACCESS POINT NAME.FOR EXAMPLE
TATA DOCOMO USE TATA.DOCOMO.INTERNET
AIRTEL USE AIRTELGPRS.COM
SO TELL US ABOUT WHAT OPERATOR YOU ARE USING AND WE WILL HELP YOU TO MANUALLY SET GPRS SETTING.
THANKS FOR USING FIXYA
Mar 03, 2011 | Nokia Classic 2700 Cell Phone
I cant set gprs in my phone
Open Menu? Settings? Configuration? Personal Configuration Settings To create a new entry click Add new, or go to Options and select Add new From the list, select Access point Set Account name as "Tata.Docomo.Internet" Then, select Access point settings ? Bearer settings, and set Packet data access point with the appropriate setting.
For example: "tata.docomo.internet"
Feb 28, 2011 | Nokia 3110 Cellular Phone
I put themes to my e63 phone. but some msg coming themes not supported pls contat vender.
YOU NEED THE GPRS SET WHICH YOU USINGH CONNETION AND I OUTHER WHO TO SOL THIS
The MMS settings (for example, MMS access point) are correctly defined in your device.
1. First confirm with your operator or service provider about the following things:
  • Data plan is activated on your SIM card.
  • The MMS settings (for example, MMS access point) are correctly defined in your device.
  • Roaming is activated when you are not in your home network.
2. If possible, insert another SIM card in your device to isolate network problems.
3. If possible, check your SIM card functionality with another device.
4. If your device supports dual mode, change to GSM mode and retry.
5. Restore the factory settings.
6. If the problem persists, visit the nearest Nokia care point.
Mar 11, 2010 | Nokia E63 Cell Phone
VPN tunnel establish using FQDN for remote end point address
Yes you can do as you expect.
ScreenOS Concepts & Examples ScreenOS Reference Guide, Volume 5: Virtual Private Networks Chapter 4 -- Site-to-Site Virtual Private Networks
"Route-Based Site-to-Site VPN, AutoKey IKE" Example
"Route-Based Site-to-Site VPN, Dynamic Peer" Example
"Route-Based Site-to-Site VPN, Manual Key" Example
"Setting AutoKey IKE Peer with FQDN" Example
"VPN Sites with Overlapping Addresses" Example ScreenOS 5.4: http://www.juniper.net/techpubs/software/screenos/screenos5.4.0/CE_v5.pdf
ScreenOS 6.0: http://www.juniper.net/techpubs/software/screenos/screenos6.0.0/CE_v5.pdf
May 03, 2009 | Juniper Networks (SSG-20-SH-WW)...
Reset time and date
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Mar 12, 2008 | Sharp EL-2196BL Calculator
Setting time & Date
I copied this from another post & it worked for me:
To enter the date
2. Enter the month
4. Enter the day
6. Enter the year
Example 3.09.2007
To enter the time
Mar 10, 2008 | Sharp EL-2196BL Calculator
Date/Time feature
To enter the date 1. Be sure to switch to "rate set" from GT 2. Enter the month 3. Press the decimal point 4. Enter the day 5. Press the decimal point 6. Enter the year Example 3.09.2007 7. Press the button that look like a clock/calendar To enter the time 1. Be sure to switch to "rate set" from GT 2. Enter the hour (please use military time) 3. Press the decimal 4. Enter the minutes Example: 13.24 or 9.24 5. Press the button that look like a clock/calendar Then change the "rate set" back to the GT setting.
Jun 14, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2615G Calculator Logo
91 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
