Question about GE Dishwashers
What is wrong with my dishwasher and how can I fix it?
My GE Potscrubber 550 dishwasher is not cleaning the items. In some cases, the soap is still on the door compartment but open or the liquid soap does not completely dissolve.
  • GE Master
  • 473 Answers
Check water temp. Needs to be a minimum of 120 degrees. Check all the spray arm holes for food blockage. Look closely at the holes on the spray arm ends. Those holes act like jet engines to spin the arms.
Posted on Apr 04, 2015
    Champion:
  • 208 Answers
Clean the arms, drains and filters thruout... Remove everything you can and clean out all you can!
Posted on Apr 05, 2015
    Top Expert:
  • GE Master
  • 10,875 Answers
Make sure that everything is turning and enough water
Posted on Apr 02, 2015
Testimonial: "everything is turning and plenty of water."
My GE Potscrubber Model GSD2230Z04WW is not dissolving the soap. I have already replaced the water inlet valve.
Check your wash arms, and make sure the holes are not plugged. Also make sure they are free to turn. Next,remove the toe-kick panel, and look for leaks or signs of leakage. Sometimes (especially if your tile floor doesn't go all the way back), dishwashers will leak most of their water out and you never know it! Other simpler things is to make sure you are not blocking the soap dispenser with large pans or plates.
Feb 17, 2015 | GE Dishwashers
Ge potscrubber 700 dishwasher - the soap dispenser cover is locked and will not open. I have run the dishwasher several times and tried to force it but it will not budge. any suggestions?
Soap dispenser cover will not open until front knob is at 4:30 or 5 o'clock. Turn knob to 5 o'clock and jiggle dispenser cover. If cover still does not open, is detergent caked such that door won't open? If yes, remove caked detergent. If no, disconnect power at breaker. GE repair manual says to remove screws for inner door panel and inspect detergent dispenser mechanism with lever and trip lever for broken or binding parts.
Oct 13, 2013 | GE Dishwashers
Ge potscrubber 940 dishwasher
My GE potscrubber, model GSH942 (very old) is not working, as one of its part was fumed (burned). Though the dishwasher is old, it was doing perfect job. Kindly advise whether there is any hope to save it. picture of damaged part is attached.
664ecbc5-d293-4bf8-9a26-d4eb60b56c88.jpg 3afc25c1-d149-45c7-8546-1d01d256fcd6.jpg 2ffcde17-d805-44d2-865f-843483703dd0.jpg
Aug 10, 2013 | Dishwashers
Hello, my 1992 GE potscrubber 630 is not cleaning well at the moment. Could vinegar or a little bleach help if it something is clogged with hardwater or food particles. thx.
My GE Potscrubber 630 dishwasher leaves a white film on all of the dishes. Is there a filter that can be cleaned out?
Aug 07, 2010 | GE Dishwashers
My ge potscrubber 650 is leaking onto the floor in front of the dishwasher. What is the likely problem?
On ours, the leak was on the right side, and it turned out to be a failure in the seal around the soap dispenser.
Mar 25, 2010 | GE Dishwashers
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Just a little water seems to be coming into the dishwasher and the dishes are not getting clean even on the Potscrubber cycle
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 06, 2009 | GE Dishwashers
Dishes are not clean; lots of soap residue
Try the combo liguidgel powder packets and wash on the potscrubber plus setting. We saw a drastic improvement with this setting. I have just about gotten out of the habit of thorough pre-washing, but I do rinse heavily soiled items.
Aug 20, 2008 | Siemens 24 in. SL84A305UC Built-in...
Dishwashers Logo
179 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
