Question about Brother PE-500 Embroidery Machine
Bobbin doesn't wind properly - Brother PE-500 Embroidery Machine
    Top Expert:
  • Brother Master
  • 43,059 Answers
Some do need a little finger help to guide the thread across the bobbin so it lays flat
Posted on Apr 02, 2015
I have trouble winding the bobbin. For some reason it starts winding it below the bobbin.
Verify that you are threading it properly for bobbin winding. Perhaps the bobbin winder height needs to be adjusted. If you continue to have problems (which I frequently have with some of my machines), I simply use a pencil or a skewer to raise the thread as it is winding on the bobbin.
Sep 15, 2015 | Sewing Machines
The bobbin won't wind, do you know what my problem is?
It is difficult to diagnose without knowing the machine brand and model.
Consult your manual and verify that you are properly following all the steps and threading the machine properly to wind the bobbin.
If you still are unable to wind a bobbin, you can pick up a stand-alone bobbin winder (one brand name is Sidewinder) sometimes available at fabric stores, ie Hancock's, JoAnn's, or Amazon for about $25.
Aug 31, 2015 | Sewing Machines
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
Tangled thread after winding new bobbin
Try winding it the opposite way you are doing it now in regards speed. If you are winding it on full speed, try winding the bobbin slower. If you are winding it slow, try faster. Also check that the thread is threading properly and is not catching somewhere, and also that the tension is correct. Finally, test with a thread that you have not experienced problems before.
Jun 30, 2015 | Sewing Machines
My Janome 3018 will not wind a nice tight bobbin. They are loose and spongy. This machine is brand new. I have double checked that it is threaded properly and the thread is in the correct place and
You are not exactly threading the machine when you wind the bobbin. So follow the directions for winding the bobbin, make sure the thread fits under the little revolving wheel, and make sure that the stitch part of the machine is disengaged.
Jan 01, 2015 | Janome Sewing Machines
Why doesn't my bobbin holder move
Have you put it in bobbin winding mode?
Sep 03, 2012 | Singer Sewing Machines
Singer 6268 bobbin winding
I've never seen this type of winding system. But from the manual on page 10, it shows that in order to disengage the machine from sewing mode.. you need to have the bobbin cover slide plate slightly open.
http://www.singerco.com/uploads/download/1272_6268-_-6268_6267-wholeas-of-6_23_05-special.pdf
Also make sure that your bobbin doesn't have any burrs. If it does, toss it and use a new one.
Jul 21, 2012 | Singer Sewing Machines
I have a new Bernina 350 and the bobbin doesn't wind on evenly. If left to do it automatically it ends up wrapped around the bobbin spool. Is this normal?
the thread has to be pretty tight around the bobbin tension guide
but I would suggest if you can't get it to wind correctly to have it check to see if there is a problem with it
May 12, 2012 | Bernina Sewing Machines
Loose boobin winding
You need to ensure that the thread is going from the thread spool at the back of the machine, through the eyelet, then around the silver tension disc on top of the machine, then to the bobbin when you are winding it. Also, pull the thread tail up through the hole in your bobbin to start and hold the tail so the thread starts to fill smoothly and doesn't loosen.
I've marked the disc in red on this image
Please read my Tip on bobbin winding; its really important to get a good wind and you can add more tension yourself by applying gentle pressure to your thread spool on the back pin as you wind off it.
Link is http://www.fixya.com/support/r10598580-winding_bobbin_correctly
The stopping when full is possibly because your bobbin is winding unevenly but I never run it until it stops itself anyway, and do the winding at 3/4 speed, not flat out. You want a really smoothly tensioned even wind onto the bobbin so your thread comes off the bobbin when stitching with even tension, not stretched, then loose.
Hope this helps you with your problem.
Dec 14, 2011 | Elna Quilter's Dream 6003Q
The bobbin thread keeps breaking! It is very loose and then snaps?? I've replaced the needle to make sure it was sharp, I bought the highest grade thread I could find, adjusted the tension... then...
Sounds more like the way the bobbin has been wound, is it loose and uneven or tight and smooth. Is it properly into the tension spring? being loose doesn't sound right, a thread under correct bobbin tension is usually pretty firm.
Is it loaded into the bobbin holder the right way ?
Also check the bobbin itself hasn't been damaged in some way, not worn/bent. It needs to turn smoothly in the bobbin holder so if one edge has been bent a little this will cause problems.
When winding bobbins, you must have tension on the thread so it winds smoothly with consistent tension on the thread. Most machines have a little tension disc on top or the thread goes through the regular tensioner in order to achieve this. But I always wind bobbins at about 3/4 speed and also add a little extra tension by holding my scissors handle on top of the thread spool so it doesnt bounce around. Also start winding with a little tail pulled through a hole on top of the bobbin and wind until this starting end is covered, then stop and snip off the tail. Then continue winding and watch the thread, giving it a nudge so that it fills evenly across the bobbin, not just all in the middle.
Think of it like the garden hose reel; if you wind it really fast the hose all goes into the middle of the reel, then jams up and you can't get the whole hose onto it. Same thing, wind smoothly and evenly across the whole depth of the bobbin so that the thread is smooth and even. Then when the thread feeds off it will be smooth evenly tensioned and should stitch out evenly.
There is some good trouble shooting information on this page too which might help you to work out what is causing this thread breakage.
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Jul 17, 2011 | Necchi Sewing Machines
Brother PE-500 Embroidery Machine Logo
41 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
