Question about Cub Cadet Garden
When was cub cadet tractor model 1864 serial #876274 built?
  • Cub Cadet Master
  • 2,478 Answers
93-97
Posted on May 26, 2015
SOURCE: hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Posted on May 21, 2009
mickey813
  • 472 Answers
SOURCE: Lawn Tractor will not start.
re place the fuse its a small 10 to 20 amp is by the solenid wer the batt cabel hooks up frome the batt
Posted on Oct 04, 2009
mickey813
  • 472 Answers
SOURCE: 7264 cub cadet tractor hydralics
the starting problem may be a lose ground wire the other is probably the pump it sets on the back of the rear end its nothad to chang it just cost aroun 850 to 900 ya thats what it cost me the last time i done one
Posted on Nov 07, 2009
  • 13 Answers
SOURCE: cub cadet lawn tractor, ran out of gas. After
I would bet that the throttle shaft is worn and has a lot of play in it on the carburator. This is very common. The best bet is to have the carburator worked on by a small engine repair shop, or get a replacement one.
Posted on Jun 10, 2010
  • 6468 Answers
SOURCE: Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
Posted on May 14, 2012
How do I find year model on Cub Cadet rzt 50
The Manufacturers Serial and model numbers should be on a plate under the seat. Go to the Cub Cadet Website navigate to Manuals, enter the Serial/Model numbers and the year of manufacture should pop up.
Sep 21, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Sep 16, 2014 | Cub Cadet Garden
Cub cadet wiring diagrams
the only way is through MTD... or sometimes the owners manual will have it
Aug 18, 2014 | Cub Cadet Model 18611862 Parts Operators...
Ineed to get the belt routing diagrams for the mower deck and rear rototiller attachment for an older cub cadet lawn tractor
GO TO INTERNATIONAL PARTS SITE, ENTER TRACTOR MODEL, SELECT PROPER DECK AND THE PARTS LIST HAS A BELT DIAGRAM BUILT IN. IF YOU HAVE AN INTERNATIONAL BELT FOR IT BEAT A PATH TO A BEARING COMPANY TO ORDER THE SAME OR BETTER BELT FOR LESS THAN 1/4 THE IHC COST.
Apr 27, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Replacing governor on Cub Cadet 1225
I have a cub cadet 1864 and the governor is out of control, the engine will race a high speeds. When i pull back the governor arm and hold it it run normal. Can some one help
Apr 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I need an owners manual for a cub cadet riding mower. series 1000. model 1042 Lt. serial # 3430203833. thank you
Go to following site http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Then type in model LT1042 and check your serial no. again as I could not get it to come u.
Mar 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Download User Manual
Go to http://manuals.mtdproducts.com then click on public site. You will need model no. and serial no.
Mar 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Mar 23, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
71 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
