Question about Epson WorkForce WF-2540 All-in-One Inkjet Printer
When I go to scan, the screen for the scanning has a drop down for source, the option for feeder is no longer on the drop down since I updated.
4 Suggested Answers
SOURCE: scanning multiple copies
The trick is to put the scanner in PROFESSIONAL MODE !!!!! Select that option in the top right corner of the Epson Scan application when it first opens up.
http://files.support.epson.com/htmldocs/gt25__/gt25__ug/projs_1.htm
Posted on Dec 10, 2008
sys_admin
  • 829 Answers
SOURCE: The drop down menu does not give the option to
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Posted on Jan 16, 2010
  • 1702 Answers
SOURCE: It wont scan, but it will print ~ been through the manual procedure several times and it wont give me the drop down screen asking for it to be named and then saved. Also when I click on the scan icon
Hi, it could be a software issue.Try uninstalling and then reinstall the software again.
Another thing you can do is download a new version from epson website. They usually have fixxes for it in the software. Look for your printer model when downloading for this. Good luck.
Posted on Dec 01, 2011
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Which software to scan ?
Down load the software for your windows 32 or 64 bit here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1138373&
You need the full package to use the scanner.
To scan a picture or document, follow these steps: Step one: Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one.
  2. Turn the product on.
  3. Load the picture or document:
    • Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid.
    • ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION: Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos.
  1. Open HP Solution Center with one of the following methods:
    • Click Start , click All Programs , click the HP folder, and then click HP Solution Center
    • Double-click the HP Solution Center icon (c01810967.gif ) on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
    • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
    c01940398.gifImportant : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings. hpweb_1-2_plus.gifhpweb_1-2_minus.gif Using the scan button on your printer HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. c01940398.gifImportant: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want.
Mar 03, 2011 | HP Officejet 4355 All-In-One InkJet...
How to scan using hp j4580. Booklet only tells how to fax!!!!
    • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    • Double-click the HP Solution Center icon on your desktop.
Jul 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
To scan from the platen glass:
1. Click the "Setting" icon on the multipass toolbar
2. Select "Toolbar Settings" tab
3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
Mar 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
I have a brother mfc-7420 flatbed and am trying to scan multiple pages through the automatic feeder but it only scans whats on the flatbed? Is the feeder only for copies and not for scans? Anything i can...
First install everything, than go to my computer at the bottom u will have Scanners and Camera, click on Brother MFC-7420 USB
Than if the window pop ups than click on Microsoft Scanner and Camera Wizard
Now u will have new Window "Scanner and Camera Wizard" click Next
On next page u will see Choose Scanning Preferences in there u will find "Paper Source"
click on the Scroll down option and pick "DOCUMENT FEEDER" and Click next
than hopefully u know wat to do pick the name fro scans that u going to make pick the folder to place it in and it will start scanning by it self and will send i to ur computer.
And put ur Scan paper with the side that u wanna scan FACE UP in the FAX tray which is on the Top or all in one Printer
Dec 02, 2008 | Brother MFC 7420 All-In-One Laser Printer
How do I scan an image from canon pixma mp150
Acquire Text The following instructions will give you the basic instructions to acquire text from a scanned document in Office Word 2007 using OmniPage SE.
  1. Ensure the Canon scanner driver and OmniPage SE are installed and that your scanner has been setup.
    Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
  2. Place the document(s) to scan on the platen or on the Automatic Document Feeder (ADF) (if applicable).
  3. Open Office Word 2007.
  4. From the ribbon menu, select the 'Add-Ins' tab.
  5. In the Add-Ins tab, click 'OmniPage' and then select 'Acquire Text Settings (OmniPage SE)'.
    The Options window will open.
  6. On the Direct OCR tab, click the 'Image Source' drop-down to select 'Scan'.
  7. Confirm 'Scan' is shown in Image Source section and then click 'OK'.
    The Options window will close and you'll return to Office Word 2007.
  8. Click 'OmniPage' and select 'Acquire Text (OmniPage SE)' to scan your document.
  9. After the document(s) is scanned, make corrections to the text items as appropriate.
I hope it helps!!!
Dec 01, 2008 | Canon imageCLASS MF7480 Laser Printer
How to scan using canon pixma mp150
I hoe it helps!!!
No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
May 23, 2008 | HP LaserJet 3055 All-In-One Printer
I can't Scan 8 1/2 by 14. It cuts the scan to that of a regular paper. I can fax by 8 1/2 by 14 and it comes out alright. how i do the set up. I used the set up in the scan but it did not help.
I also had problems scanning legal size documents with a Brother MFC-7440N. The documents would scan but would not come out complete. A large portion of the text would always be left out and only an image of the size of regular page size would come out. I knew it had to be something with the settings, so after experimenting with my MFC-7440N I came to the conclusion that I was not going to find the solution on the actual machine. I had a "Hunch" that I would find my solution by connecting the printer to my laptop computer and use the software that came with it. After a couple of minutes I was able to scan Legal Size documents in a breeze... I should of done this months ago. All scanned docs came out in full size.
So I took some screen shots to post them up here to let everyone know how to scan legal size documents since I noticed that people are having trouble just like I did. With this instructions you will also be able to scan any available size documents with a Brother MFC-7440N. I will also guide you step by step. After step 4 the remainder steps are OPTIONAL unless you need to change the color or picture file types. Okay, here we go!
Step 1.
Make sure your MFC-7440N is connected to your computer and the computer has the software installed that came with the printer.
Place the Legal Sized documents/papers that you want to scan on the Paper Feeder Scanner located on the most upper area of the machine.
Step 2. On your computer, go to START then to DEVICES and PRINTERS, or CONTROL PANEL then DEVICES and PRINTERS. Locate the icon of your MFC-7440N. If its not your DEFAULT printer make it the default one. Then RIGHT Click on the icon. A menu will pop open. Locate START SCAN and click it.
Step 3. A small window will open that will give you various options to scan a multitude of sizes and different settings. Locate where it says SOURCE. The default setting might be FLATBED meaning the flatbed scanner of your machine. Click the drop down menu and select FEEDER. By selecting the feeder option your computer will tell your machine to use the automatic paper scanner located on the most upper area of your machine.
Step 4. Locate PAPER SIZE. Click on the drop down menu and then select Legal 8.5 x 14 inches (216 x 356mm).
If your documents are already located in the feeder you can now go ahead and click SCAN and your documents will begin to scan.
Your scanned documents will be saved in a file folder in your computer and that file will pop open for your convenience once all documents are scanned.
If you need to change COLOR or Black and White setting plus Picture File Types such as Jpeg or Tiff just click on their respective drop down menu before clicking SCAN.Here are some pictures to help me illustrate it.
I hope you find this helpful.
Thank You!
Visit me at:
Facebook.com/BestCreditRepairManualor at
BestCreditRepairManual.com 92c85b21-a89d-4f9a-bf67-a96f103f2c15.jpeg 6adfe3bc-45ef-4e80-a6b2-7b825e659868.jpeg da5aa6de-6531-4fb6-9f91-3a1b503ac89c.jpeg 36e97075-1229-4d28-b14c-e7371ad26589.jpeg 15d2f41b-30e0-42cd-9e6d-663e9bb17a3c.jpeg 6d240b8f-2360-4094-8d6b-0c8cd404332c.jpeg 4203c1e5-8b35-4dc9-a802-65652251f028.jpeg
Oct 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
Epson WorkForce WF-2540 All-in-One Inkjet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
