Question about EdgeStar 2.0 Cu. Ft. Washer Dryer Combo with Portability Kit - CWD1510WPORTK
Error code E3.. - EdgeStar 2.0 Cu. Ft. Washer Dryer Combo with Portability Kit - CWD1510WPORTK
  • EdgeStar Master
  • 1,205 Answers
Good evening Cathyl
Lucky you, you have got the manual . I have just looked through it. Your machine has some wonderful features, that my combo machine does not have. Since you have got the manual, look in the troubleshoot chapter for what happenes when Error code 3 appears. Look for what the machine isn't doing but should be doiing. Good luck
kolbrun
take a look at this page, see if it helps.
k
Posted on Apr 02, 2015
    Problem Solver:
  • 9 Answers
Your problem is in the water pump, you have to take the fromt panel off and look for the water pump, and it can be opened, take it apart and clean it up ( this happened to mine and after cleaning works great) I f this doesnt work for drying the clothes ( error code E3) then take hose off oppisite end of water pump and see if it is pumping out water with washer machine on and in the drain mode.
    Genius:
  • 1,175 Answers
Manual is here
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-ES-Site/Sites-ES-Library/default/v1427954440473/support/manuals/CWD1510W.pdf
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
The machine does not make copies showing an error E3 which i can not see where i can find it
yep!
e3 means a machine error and it need a service technician to fix it.
furthermore may i ask what e3 code displays on the screen (you might see something like this e3 10 , e3 40 , e3 01 etc)
i can still help you if it is e3 10
Jan 04, 2010 | Panasonic FP-7735 Black and White Copier
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
Getting code E3. What does this mean?
error E3 means Paper jam ..try to clean any paper inside...
May 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Aug 26, 2008 | Pitney Bowes C180 Copier
EdgeStar 2.0 Cu. Ft. Washer Dryer Combo with Portability Kit - CWD1510WPORTK Logo
109 people viewed this question
Top EdgeStar Washing Machines Experts
Are you an EdgeStar Washing Machine Expert? Answer questions, earn points and help others
