Question about Frigidaire Heating & Cooling
Wiring diagram for fs3bc-036k - Frigidaire Heating & Cooling
How do I fix my Frigidaire A/C unit Model FS3BC-036KA (3.0T)
You are low on refrigerant. You need to find a service location that can recharge it for you.
May 08, 2015 | Frigidaire Heating & Cooling
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
(nordyne.com)
Sep 13, 2014 | Frigidaire Heating & Cooling
I need a miller a/c p1ra-036k wiring harness
If you mean a pig tail from the disconnect to the condenser go to a furnace supply and get one there. About $20.00
Jun 12, 2014 | Intertherm Heating & Cooling
No heat fan runs heat elect ok
I would recommend fixing the fan right away. So the heat runs fine but the fan never starts? Check the wiring connected to the fan, there is probably just a disconnected wire.
Elisa Jed ' http://www.jandsheatingandair.ca/en/services.html
Jan 22, 2014 | Intertherm P3RA-036K Air Conditioner
Nordyne T3BA-036K trips breaker on outdoor unit immediately will not stay set
Hello, sounds like a short to ground. Check all the wiring to make sure it is not touching any metal. If the wiring appears ok then the compressor windings are shorted to ground and the compressor will need to be replaced.
Jun 04, 2012 | Heating & Cooling
Where can I find a wiring diagram for a interrherm
Hi; Call Your local mobile home supply house and they can tell You how to or fax You the Info. Also the equipment will have the wiring diagrams glued to the inside covers of the outdoor unit as well the indoor unit cover. Power down the indoor unit before removing the indoor electrical cover for the schematics. Do You not have a user or install manual. Call your local mobile home supply house they can often help.. Be care full You get more bees with honey so be very nize...alpharome416
Feb 19, 2010 | Intertherm P3RA-036K Air Conditioner
Need a product manual for intertherm model p5rd-036k
http://www.nordyne.com/Literature/455a.pdf
and here ya go. check this web site for your manual.
Hope this is what you want.
Dec 26, 2009 | Intertherm P3RA-036K Air Conditioner
Relay board for thermostat/condenser fan/n compressor need to mak
I have a copy of the wiring diagram for this unit. If you would list your email address, I will email the diagram for you. This will give you everything you will need to insure that the unit is wired correctly.
Mar 20, 2009 | Intertherm P3RA-036K Air Conditioner
Heating & Cooling Logo
124 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
