Question about Husqvarna Garden
Have a 22hp husqvarna mower 54"deck motor has a miss when I go full throttle or half throttle in thick grass and blowers out black smoke like it is loading up on gas.What is my problem
    New Friend:
  • 56 Answers
It gets rich when under load. Okay the governor is trying to open the throttle.
Can it? pop open the engine shroud and carb cover and see if the linkages are free. I get mouse nests in there and it screws up the governor and choke.
Posted on Apr 04, 2015
    New Friend:
  • 16 Answers
You might also need to adjust the carburetor to increase/decrease the air/fuel mixture. You should be able to locate the adjusting screw on the carburetor and turn it slightly in one direction and then the other while the engine is running full throttle. The screw can usually be identified by the spring under the screw head. You will be able to hear the engine smooth out or begin to miss as you do so. Stop adjusting when it is sounds like a Swiss watch; smooth and constant.
Posted on Apr 02, 2015
  • Corey Cash Apr 02, 2015
    We have cleaned carb. And adjusted the valves was concerned if I could have a burnt valve or a simple thing like a coil pack
    Scholar:
    New Friend:
  • 61 Answers
Well, the simplest cause is a plugged air filter. Insufficient air with the usual amount of gas causes a rich, smoky mixture. Clean the air filter and make sure it isn't clogged with grass clippings.
5 Suggested Answers
  • 6 Answers
SOURCE: Drive belt diagram
go to sears.com and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
Posted on Apr 30, 2009
  • 6468 Answers
SOURCE: Mower deck blade speed slows in thick grass.
if the belt is tight then it must be the clutch slipping the clutches cost $200-$300 so double check the belt
Posted on Jul 04, 2012
philwalker78
  • 608 Answers
SOURCE: mower blades speed slows down in thick grass, the engine speed remains constant 217D
Hi, check that the belt is not worn and bottoming out in any of the pulleys and also check that none of the deck spindles are stiff to turn with the belt removed. Regards Phil.
  • 401 Answers
SOURCE: Will a 22hp Kohler engine replace broken 27hp
I don't think it will easily interchange. Of course you can always adapt anything, however don't think this is a good idea. Not with a 54 inch cut. Kohlers are usually easy to repair and overhaul. I would try to replace with same engine.
Posted on Aug 24, 2014
My husband bought a 2011 Husqvarna YTH2348. I am the one that mows the grass. We had the mower serviced last week. We have a HUGE lawn and I mowed all but the orchard. The next day, I went out to finish...
Black smoke is generally indicative of a rich fuel system. whitish blue smoke is generally burning oil.
It sounds like there is something wrong with the fuel metering at full throttle. You might check that the mechanical compression release isn't coming on when you go to full throttle.
Aug 17, 2013 | Husqvarna Garden
How do I install a mulching Kit on my Husqvarna riding lawn mower?
having trouble with mulching unit on 22hp tractor.Mulching kit installed by dealer at time of purchase.What is happening is grass is kicking up on the top of the mowing unit,covering the belts and everything else.I need to do a major cleaning every time I use the tractor.Any one got some solution.
Apr 09, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
Leaving streaks of grass in middle of mower
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
Sep 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Spark plugs are being replaces every 3 or 4 mowing
the carb is located under the aircleaner it sounds like the mower is being fan at full throttle this on some mowers applies the choke try ajusting the throttle to full then slightly back to open choke.
Jul 14, 2009 | Mtd 22" Yard Machine Push Mower
My Husqvarna lawn tractor started smoking terrible about half way through cutting the grass today. Oil dripped out of the muffler. What is that a sign of? Have I blown the engine? I check tires and oil...
You mean Briggs and Stratton. Sounds potentially expensive. Call a local small engine repair shop. They'll tell you how much it will cost. A new engine might be $1k. Repairs a few hundred.
May 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Drive belt diagram
Apr 30, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Garden Logo
120 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
