I have got a honeywell st9400c boiler. We had a power cut .when it came back on it started flashing f1. Radiator so will not heat up now
  • 79 Answers
Turn off the thermostat, then turn off the breaker to the boiler, wait 5 minutes, then turn on the breaker and look at the readout, if OK then turn up the thermostat.
Posted on Oct 05, 2015
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
My honeywell timer for the back boiler heating is blank
need to contact the people who worked on it yesterday to come back and look at it again because it sounds like you have no power to now.
Jan 29, 2010 | Honeywell CT3600 7 Day Electronic...
I have a Honeywell Thermostat CM67NG The flame symbol is showing on the thermostat, but there is no heat from radiators. The status code on boiler says there is ' no heat demand'. Boiler shows radiator...
You may have a broken thermostat wire. Disconnect the wires from the thermostat and please note what colors are hooked to which terminals. Cross the R and W wires and see if your heating system turns on. If it does not, you have a broken wire or bad connection at the heating system. If it does start, you have a bad thermostat or bad connection at the thermostat.
Nov 30, 2009 | Honeywell Programmable Thermostat Heater
Need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Oct 18, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
207 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
