Question about Exercise & Fitness
Do you have a wiring diagram for the circuit board of a Keys Pro Series 400 treadmill?
One small electronic component burnt out when my son's acreage had a power surge. I need to find out what the component was so I can get a replacement. John Hamblin
  • John Hamblin
    John Hamblin Apr 04, 2015
    Thanks for responding to my question. It is appreciated. What happened with the treadmill was this: My daughter-in-law was exercising on the treadmill when she saw a puff of smoke coming from the treadmill which suddenly stopped working. We took the cover off the treadmill and examined the circuit board finding a small electronic component that had burnt out. On checking with the utility company we were told there had been a surge of power that lasted only seconds, but it would seem it was long enough to burn out one of the electronic components. My son and his wife live on an acreage where surges are a common occurrence. We have tried to find a company in the area that repairs treadmills but there are none, and the original manufacturer has gone out of business, and it also appears that the circuit board manufacturer is off shore. More than that I cannot add anything. If you have specific questions I would be happy to answer them. If we can get a wiring diagram we could determine what component has burnt out and we can replace it. Thank you. Sincerely, John Hamblin
5 Suggested Answers
SOURCE: Wiring diagram need for an Smoothfitness EVO treadmill.
Solved this problem by contacting the Evo/Smooth directly. Great service.
Posted on Oct 20, 2009
  • 95 Answers
SOURCE: I need a wiring diagram for a pro form 730
There are many different kinds of Proform 730 models. Please search for or find your specific Proform model here and look at the parts list for the accurate wiring diagram for your model.
Posted on Mar 09, 2012
ercupa190
  • 12223 Answers
SOURCE: nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Posted on Oct 01, 2012
ercupa190
  • 12223 Answers
SOURCE: Schwinn 5450 treadmill power to fuse on circuit board, but no operation
HOwever test the c. breaker and reset.
If the problem persist LUBE the deck belt+rollers bearing see the video attached.
see the diagram attached in case that you need to troubleshooting.
Posted on Feb 18, 2013
How do u incline the keys 400 Treadmill
hi,
Here i have added a link to the manual of Keys Fitness PRO 400 treadmill. Down load the manual. It would be there in the manual how to use the incline the treadmill you have.
http://fitness.manualsonline.com/manuals/mfg/keys_fitness/pro_400.html
www.electro-medical.blogspot.com
Oct 30, 2015 | Exercise & Fitness
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
Fan problems
this is indicative the some electronics components is in short circuit in the pcb. You must replace. However RUN the software calibration for diagnose, and fix it. see the block diagram.
you can measure the input voltage for the main motor if there are the motor is o.k and vice-versa
2) you can measure the output meassure from the pcb board is there are NOT the board is faulty for the input voltage motor.
Jun 05, 2013 | New Balance 1400 Treadmill
Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Feb 18, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
Bowflex series 7 treadmill Calibration fail. Next indicated action?
It looks like the main circuit board is damaged and needs to be replaced unless there are separate modules in it.
Jan 22, 2013 | Bowflex Series 7 Treadmill Folding Pro...
Hi. I have a Horizon T-62 treadmill. It stopped working during a workout and my son smelled an electrical burning smell and saw small puff of smoke. I removed motor cover and reset circuit breaker then...
Unfortunately it sounds like the motor has burnt out and would require replacing.
As this treadmills come with a 10 year warranty on the motor if you've not had it for that long the you need to contact Horizon Fitness at the link below.
http://www.horizonfitness.co.uk/6/service/
If they're unable or unwilling to help you then please ask for further assistance and I'll see what I can do.
A replacement motor is in the region of $400 + fitting, but you could possibly fit it yourself.
Jun 22, 2011 | Exercise & Fitness
Please can anyone help me I bought a 560hr treadmill today second hand it was workin perfectly, until my son and grandson went on it ..it now will turn on but the belt will not go it trips the power switch...
12_7_2011_9_56_59_pm.gifSee the block diagram that I did for you. Now you will see how many elements or component has the treadmills. If the fuse or breaker are trips. you must inspect and test: 1) Power cord some internal wires is touching insider and produce short-circuit. 2)Capacitor in short 3) Coil or transformer in short 4) Main Motor in short 5) Main Controller Board.
Finally see for any wire is loose and touch the chassis from the machine in that case produce a BIG SHORT. sincerely.
Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Apr 03, 2011 | Proform 560hr Treadmill Walking Belt
How do i unhook the electrical connection from the display to the power wire?
You must watch the flexible cable or connector from display board vs Lower
Board or Main Motor Controller.
Then you must isolate the Main Motor Controller from Power Supply coming from coil or Transformer. +Pull out the fuse and turn Off.
See the block diagram that I did as people like you for yourself take carefully.
11_29_2011_4_39_37_pm.gifFinally to make short circuit in Boar or component. sincerely.
E.CUADRA
MANAGUA, NICARAGUA.C.A
Nov 18, 2010 | Nordic Track NordicTrack A2750 PRO...
Oct 19, 2009 | Exercise & Fitness
The dishwasher will not turn on
Congratulations - you found the fault !
The options you have are -
Buy areplacement board from a spares centre.
Buy a take- off board from a scrap one on Ebay.
Or - Learn about electronic repair - and identify the burnt component , buy the parts and replace it yourself.
You can take it to an electronic repair shop - if you can find one - or a electronic supply shop - and ask for a new one of "them".
If replacing a burnt component - often there is a cause other than just that component.
Experience tells you what else might be wrong to cause it.
Aug 04, 2009 | Maytag MDB9600A Jetclean II Built-in...
Exercise & Fitness Logo
101 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
