Question about Brady TLS 2200 Label Printer
Print preview looks fine but just get a blank label from label mark. prints ok when not done from pc
  • mark mulvany
    mark mulvany Apr 03, 2015
    thanks for reply, im using labelmark 6 software and have the latest drivers.
  • Jerry Hirschinger Apr 03, 2015
    My only other suggestion would be to check to be sure the PC is using a printable font and color for that labeller, and that the PC is not placing a Linefeed or Carriage Return character in front of the text.
  • 156 Answers
You likely need to use Brady's software to create the label on the PC, and your PC will need the correct printer drivers to communicate with the Brady. The software and drivers should be available from Brady.
Posted on Apr 02, 2015
  • mark mulvany
    thanks for reply. im using labelmark 6 software and have the latest drivers from the brady website
Label is printed fine but each printed label print blank line before label print
To isolate problem run a test label from printer.Does the same thing happen? If so it is a printer problem.If not the problem is in the document itself.
Apr 24, 2014 | Zebra LP 2844 Thermal Printer
Prints blank page
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on your computer, in your software of choice, or even on your printer, a blank page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with your document and ready to print.
Observe your document.
If you see an extra, blank page, you have created a second page.
To delete the second page, close Print Preview, go back into the document and eliminate any blank lines in your documents that you may not need.
You may also find an inadvertent page break at the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print, within the Print dialogue box.
This is typically done by selecting the "Print From" option, then entering the page numbers desired.
If your document happens to be ten pages (without, of course, that final blank page), then enter in the "Print From" field the numbers "1-10".
This will print only pages 1 through 10, without an eleventh (blank) page.
Jul 11, 2013 | HP Deskjet 5940 Photo InkJet Printer
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
Hi, I have DataMax ST3210, while printing it is instering a blank page randomly. Please advise
Check that your format is centered top and bottom on the stock, and that you have at least 1/8" quiet area top and bottom.
If you are printing on stock with an eye-mark, ensure that your print does not interfere with the area at the eye-mark. The printer will try to print the format, but if the eye-mark is in the way, even if the format is printed completely, will feed a blank label.
The also applys to standard die cut labels. with standard 1/8 die cut between labels
Nov 10, 2010 | Datamax DMX-ST-3210 Printer
I guyz. my hp officejet printer works very fine as in you send document to the printer but the most amazing thing is that afetr printing and you discover there is no ink on the printer page. Please...
Hello
Before actually printing your report, use the Print Preview function to see how it will look. If there are blank pages, you will see them in Print Preview.
To use the Print Preview function, simply open the report, click on the "File" menu and choose "Print Preview" from the file menu. You will then see your report just as it will look on the printed page.
Scroll through the report for blank pages. If you see blank pages, it is an indication that the data on the report is wider than the paper you are using. You can use your printer properties to change the size of the paper if you wish. If you have access to legal-size paper, you may be able to print the report on the larger paper. If legal-size paper is not an option, you will need to adjust the margins so that the blank pages are eliminated.
To adjust the margins of your report, click on the "File" menu and choose "Page Setup" from the drop-down box. Go to the Margins tab and adjust the margins as needed. It may take a bit of experimentation to get the margins just right; toggling back and forth between Print Preview and Page Setup will make the process faster and easier.
Click on the "Page" tab and choose either portrait or landscape orientation. Changing the orientation to landscape may allow all the fields to print on the same page, thus eliminating the blank pages and saving your paper.
Nov 05, 2010 | HP OfficeJet d145 InkJet Printer
Can only print one label when I set up Avery Labels
Hi. Look at the label contents. I believe the top corners of the group is touching the header. Meaning it should only print 1 time.
Make the content smaller and be sure it is inside the body area.
Jan 23, 2009 | FileMaker Pro 7 for Mac, PC
Roxio Label Creator won't print labels (blank with scissors)
Go to the label creator in your Roxio 6, Click on EDIT, then click on PREFERENCES, go to the DISC tab and unclick the "Print Disc cut Lines" and the "Print Disc outline" boxes. This should fix your problem.
Sep 13, 2008 | Roxio Easy CD & DVD Creator 6...
Printing blank labels
I am having the same problem! Printing blank labels. Don't know what's wrong now. It was working fine yesterday.
Jul 22, 2008 | Dymo LabelWriter 400 Thermal Printer
Brady TLS 2200 Label Printer Logo
355 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
