Question about Brother DCP-8045D All-In-One Laser Printer
How do I reset dcp-8045d hex dump mode
Originally had out of memory on lcd screen. inserted addt'l memory card to 128. now lcd screen has hex dump mode and prints page after page of garbage. I can make copies, but can not sent job to printer from pc
    New Friend:
  • 34 Answers
Probably the easiest way to turn off the Hex Dump mode would be to reset all printer settings. There should be a reset menu that will allow you to reset the printer to factory defaults. After which it should recognize the new ram and print normally.
Posted on Apr 02, 2015
Testimonial: "the first answer I got worked like a charm. answer. turn off printer, hold down stop/exit while simultaneously turn printer back on. continue to hold down exit button until turns completely back on, whaalaa. fixed. thank you, been hex dumping for two days."
***STOP: 0x000000EA(0X81D46020, 0X82849438, 0XF8911CB4, 0X00000001) ati2dvag begining dump of physical memory hardware device vendor for driver updates this appears on a blue screen after my pc stops...
The video driver is corrupted. Uninstall the one you have now from Programs, reboot at least twice then download (as in Save, not Run) the latest one from here
http://support.amd.com/us/gpudownload/Pages/index.aspx
Wait for the download to end and install it.
If you get the same after that then the video card is dying, replace it.
Jan 13, 2011 | Gigabyte GV-RX13P256DE-RH RADEON X1300...
I need to know the number for the toner cartridge for a DCP 8045D all-in-one laser printer
The OEM number from Brother is TN540 for a standard cartridge and TN570 for a high yield cartridge (more toner)
Jan 04, 2011 | Brother DCP-8045D All-In-One Laser Printer
Brother DCP 8045D prints and copies but won't scan
Check out that the Scanner USB cable is connected to the PC apart from the printer Cable
Mar 08, 2010 | Brother DCP-8045D (Bundle) All-In-One...
How do i get video to workon my vivitar vivicam x327
Video Mode
Press the MODE button to select the Video mode.
Note: The camera has limited internal memory allowing you to record up to 20 seconds in QVGA. An SD
card (up to 8GB) needs to be inserted in order to use the video mode normally.
When the icon appears on the top left corner of the LCD screen this indicates that you are in Video
mode.
1. Prepare the object or subject you wish to record.
2. Press the Shutter button to begin shooting the video.
3. The elapse time will appear on the top right of the LCD screen and the icon will flash on the
LCD screen.
4. Press the Shutter button again to stop the recording and save this file in AVI format.
Note:
1. You can preview the AVI files in Playback mode or once downloaded to your computer by using
Quick Time and Windows Media Player.
2. When the camera's memory is full, the “Memory Full Insert a SD Memory Card to Transfer and
Shoot More video!” message will appear on the LCD screen when you attempt shoot more videos.
Download the test file from the internal memory to the PC or delete them to shoot more videos.
27
Alternatively, you can insert a SD memory card to expand the memory to record longer videos.
3. The LED will light up when the light condition is not good.
Feb 22, 2010 | Vivitar ViviCam X327 Digital Camera
I am sending raw data to the printer. Where to find ESC codes for different control ops
This feature allows experienced users to see exactly what data is
coming to the printer. This can be useful in finding software
problems. When you turn on the hex dump function, the printer
prints all commands and other data in hexadecimal format, along
with a guide section to help you find specific commands.
To use the hex dump feature, follow these steps:
1. After you make sure the printer is off, open the cover.
2. Hold down the FEED button while you turn on the printer.
3. Close the cover.
4. Run any software program that sends data to the printer. The
printer prints “Hexadecimal Dump” and then all the codes it
receives in a two-column format. The first column contains the
hexadecimal codes and the second column gives the ASCII
characters that correspond to the codes.
Hexadecimal Dump
1B 21 00 1B 26 02 40 40 . ! . . & . @ @
1B 25 01 1B 63 34 00 1B . % . . c4 . .
41 42 43 44 45 46 47 48 ABCDEFGH
❏ A period (.) is printed for each code that has no ASCII
equivalent.
❏ During the hex dump all commands except DLE EOT and
DLE ENQ are disabled.
5. Open the cover to set the printer off line, so that it will print the
last line.
6. Close the cover and turn off the printer or reset it to turn off the
hex dump mode.
PLEASE CHECK THE LINK TO GET THE ESC CODES:
http://www.mit.edu/~vona/MSim/vona/terminal/VT100_Escape_Codes.html
Hope this helps u ..............
Feb 21, 2010 | Epson TM-T88III Thermal Printer
DCP 8045D Display says Hex Dump Load - What does this mean - How do I get rid of it
I resolved the " Hex Dump Mode" problem
Step1: switch off power
Step2: press and hold Stop/Exit ( Red Color Key ) switch on power supply .......
now no " Hex Dump Mode" problem
Jan 19, 2010 | Brother DCP-8040 Copier
Printer is is photosmart express mode and won't print document. Screen says 'you can insert a memory card'
if the printer is usb memory card type,, remove all memory chip or usb to printer, only connect it to computer pc and give command for printing.
Sep 28, 2009 | HP Photosmart C4180 All-In-One InkJet...
Brother DCP-8045D All-In-One Laser Printer Logo
154 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
