Question about Wolff Sunquest Pro 24RS 220 Volts
How do I remove the plastic canopy on top to get to the electrical wiring?
How do you separate the two parts of the plastic to remove canopy on graco snug ride car seat?
There are two styles for the Graco Snugrides. Older canopies simply have a plastic "claw" the you pull away from the seat where the hinge of the handle is located.
Newer seats have a button on the side of the seat where the canopy attaches to the seat (also near the hinge of the handle).
I hope that makes sense.
Jul 12, 2014 | Baby Gear
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
I can't remove the canopy on my graco snug ride car seat to wash it. I'm having trouble separating the two parts to get the material off.
The two plastic pieces clip together inside the fabric of the canopy, but if you push the fabric all the way to one side, you can expose the latch where the two pieces meet. The two pieces are identical, so you can push in on the tab on either piece to separate them. You have to push firmly, but they should separate easily.
Once you've washed the canopy, just thread one of the plastic pieces through the canopy and snap the two back together by sliding them together.
Hope that helps!
Aug 20, 2010 | Graco Snugride
How do I remove the canopy from evenflo infant carrier?
use a tiny flat-head screw driver to pull outwards on the tab (this is a blue plastic tab on mine) that holds the white plastic u-shaped (canopy part) in. I didnt think it would be this difficult but it is... the graco ones are much easier to take off to wash.
Apr 18, 2009 | Evenflo Embrace
Frog canopy removal
Pull gently on the plastic arches that support the canopy (on either sides - where they connect to the stroller) and slide the canopy off.
Nov 05, 2008 | Bugaboo Frog Stroller
Dismantleing canopy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Aug 26, 2008 | Graco SnugRide - Clover
Changing the Canopy
The canopy has two plastic poles for shape that you can remove so you can put the material in the washer.
Aug 18, 2007 | Eddie Bauer Musical Rocking Bassinet...
No Power - Problem locating fuse
I have repaired many Gaggenau extractors before. On this model you were correct to remove two top screws from duct. The top and lower duct slide inside each other, and should be removed as 1 unit, by lifting the lower duct UP and then away from the wall. Sometimes there are two further screws holding the bottom duct to the canopy. Remove the filters and check for screws from inside canopy. Once ducts are removed you will see the a box, metal or plastic. Remove lid and you will see the pc board. There is a 10A fuse on there. Some models do not have fuses, and the whole board should be replaced! Good luck! C.
Nov 26, 2006 | Gaggenau AH 400-701 Kitchen Hood
Wolff Sunquest Pro 24RS 220 Volts Logo
62 people viewed this question
Top Wolff Health & Beauty Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
