Question about Science & Laboratory
DO YOU HAVE A MANUAL ON HOW TO FIX THE STAGE GEARS?
  • 2,992 Answers
Try manualslib.com, or MFG website, or email their customerservice. Usually they are quite helpful.
Posted on Apr 02, 2015
I have a DSZC16 manual indicates 2 stage compressor does that mean it increases speed when needed?
2 or 3 stage compressors normally run at a constant speed
the stages are from different size pistons
1st stage is a large piston for low pressures that feed to a second smaller piston for higher pressures and for 3 stage to an even smaller piston to get really high pressures
for example 1st stage =100psi
2nd stage =1500psi
3rdstage =3000psi
your manual should explain the set pressure for the compressor if the compressor speeds up , that is a two speed unit
Sep 12, 2017 | Air Tools & Compressors
How to fix code B0044
1. This code refers to a problem with the steering wheel stage 2 air bag circuit.
2. Disconnect the dual stage air bag connector at the lower steering column.
3. Substitute 2 ohm resistors across the stage 1 and the stage 2 circuits to the Sensing Diagnostic Module (SDM).
4. Recheck for codes. If no codes are set, reconnect the connector, remove the air bag and install the 2 ohm resistors across the stage 1 and stage 2 circuits.
5. If B0044 resets, replace the clockspring.
Feb 14, 2015 | 2003 Chevrolet Trailblazer Ext
1994 automatic transmission A4LD slow upshift in all gears
low fliud pressure in transmission..check levels and change fluid/filter and retry vehicle.
Feb 10, 2013 | 1994 Ford Ranger Supercab
Can shift gears not started, but once engine is on can't shift
auto or manual would help, i would say clutch in a manual or damage to auto gear box or torque convertor if automatic. manual is a cheap fix auto may be thousands.
Jan 17, 2013 | 1994 Honda Accord
I have a honda ccr2450 and with the heavy snow today it clogged and now the auger doesnt seem to turn to speed and is slipping, not throwing snow etc, is this an easy fix. thanks carl
You have a two stage snow blower. The first stage in your auger and they are equipped with a safety shear pin. Consult your owners manual for proper pin or shear bolt replacement.
Feb 26, 2011 | Toro Garden
I have a Toro 824 XL, electric and manual start, 2 stage, 5 forward and 2 reverse gears and everything runs great except the thrower. When I pull the handle to run the thrower, I get a screeching sound...
There is probably a pulley froze. Without seeing it can't tell you which one. But you can disengage the thrower and reach under and try to spin the pulleys, the one that won't turn is the culprit. Depending on your level of mechanical ability you may have to take it to the shop. Hope this helps you out.
Dec 09, 2010 | Garden
Nikon Optiphot stage is falling
This might be sign of trouble, because the Nylon gears inside might be worn out. I did not noticed a tension ring on Optiphot 1 or 2. The Nikon S and Metaphot from 1960s to 1976 have Nylon gears with tension ring adjustments.
Nov 25, 2008 | Nikon 7314 Binocular Microscope
Head bolts torque settings
According to my haynes manual for G-S reg, 1989-1998 it goes as follows,
Stage 1:- Tighten all bolts by hand until bolt heads just contact cyl. head.
Stage 2:-Tighten all bolts to 40Nm or 30lb ft.
Stage 3:-Angle tighten all bolts a further 60 degrees.
Stage 4:-Angle tighten all bolts again a further 60 degrees.
Stage 5:- M12 x 140mm bolts ONLY angle tighten a further 20 degrees.
Hope this helps everyone, sorry it seems longwinded but that is how it's written in the manual.
Oct 26, 2008 | 1995 Land Rover Discovery
Science & Laboratory Logo
865 people viewed this question
Top Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
