Question about Exercise & Fitness
My pro form xp 580 won't start up. It won't turn on
  • 50 Answers
I dont mean this as a smart axx, but:
Plug it in...
Turn on the switch...
Ensure the safety key is fully inserted...
Press the program / on button...
Still nothing? Check to make sure the outlet is hot and the breaker not engaged. If still nothing then this will require a disassembly and check of your machine. Best wishes.
Posted on Apr 02, 2015
maxtreadmill
  • 832 Answers
SOURCE: My Pro Form 580 XP slows down suddenly while on,
If you have not ever lubricated the running deck then I suggest doing so . What happens is that the lack of lubrication will tend to make the belt drag thus slowing down the belt making the motor control board to try to compensate the drag.
Posted on Apr 21, 2010
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
roadtech7
  • 297 Answers
SOURCE: i PROPPED UP MY PRO
There is a knob about halfway down or up, depending on how you are looking at it. You need to lift up or push up a little bit to take the weight off the locking pin, as soon as the weight is of it should pull out about 1/2 of and inch. Be careful ALL the weight of the walk deck is now in your hands. Be prepared to lower it, and use your second hand immediatly anfter you pull the locking pin out. After the walk platform starts to come down, let go of the locking pin, it has a spring to pull it back, but the pin only fits in ONE hole in the prop rod, so it wont grab on the way down. Some treadmills have a dampening shock to allow the lowering of the walk deck slowly, and some do not. So again BE CAREFULL, this could hurt you if it falls on you.
Hope this was helpfull
Posted on Nov 10, 2010
ercupa190
  • 12223 Answers
SOURCE: Pro form 995 motor won't turn on
Dear Sir:
You must do the following:
1) You must check the receptacle wall, for 115volts AC,60hz
2) If Not voltage 115 Vac, check breaker or fuse from the Panel( Main) or Sub-Panel for that circuit.
3) If there are 115 Vac, so proceed with the wires of the plugs, retigh conection and see if the contact of the plug is clean or oxide, ( clean with ethilic alcohol 100%) .
4) Check the Main button if there Voltage use the VOM( Voltimeter) , after check the push button Start , clean this .
5) If not work, check the relais and clean with ethilic alcohol 100% in the Board Controller, after check the Breaker.
6) If everything is o.k now proceed to Start the Motor.
7) In short proceed Step by Step with the logic for Troubleshooting.
Please reply is everything is o.k or you need more assistance, Sincerely . God bless you.
E. Cuadra
Posted on Sep 05, 2011
ercupa190
  • 12223 Answers
SOURCE: My pro form 580 si won't reach max speed. Why is
Dear Sir:
Adjust the speed sensor very weel see the diagram attached, tigh the connector wires very well, and clean the s. sensor very well.
2) Run the software calibration for easy diagnose , fix it, and trouble.according with your manual instructions.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Posted on Apr 05, 2012
I have a pro form xp trainer 580. When I plug it in, the display turns on but the treadmill won't start. Also, the display only shows when the key is not inserted. When I have the key on, it displays an...
Hi this is Jamie from FitFix.ca. You'll need a new console. You can contact Icon or Proform and they can assist in getting you the right part. Good Luck
Sep 25, 2017 | Exercise & Fitness
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
I have the Pro Form 580 Lt Treadmill. I have never been able to program it to play music or much else either.
Dear Sir:
I recomend you to read careully you user manual, and follow the steps.
If you do no have u. instruction download free: www.fitness.manualsonline. com
Apr 10, 2012 | Proform 580 LT Treadmill
Dear Sir:
ernesto cuadra
managua, nicaragua.
Apr 03, 2012 | Proform Exercise & Fitness
My pro form x550 does not have any plugs for it only the main power cord when i plug it in it lights up blue and thats it
What your problem? I can not understand for what you additional plug? Explain very clear. Please, Thank you in advance, sincerely.
E.CUADRA
MANAGUA,NICARAGUA
Oct 12, 2011 | Proform XP 580 Trainer Treadmill
Does not turn on. When I press the re-set button, it lights up and then goes off again.
Hello. This happened to me when I bought a Pro-form XP 550, and the solution was very simple - There is a magnectic thingy on the front attached by a string to the treadmill. The thingy needs to be stuck to front of the treadmill for it to work. It's some sort of safety device which cuts out the treadmill if you fall off. Is that it? Stephen.
Oct 31, 2010 | Proform XP 580 Trainer Treadmill
Describe how to unfold a treadmill, pro form ex
May 31, 2010 | Proform Exercise & Fitness
My Pro Form 580 XP slows down suddenly while on, and speeds up again almost making me fall off of it. Anyone know why this could happen? The manual is no help.
Apr 21, 2010 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
