Question about Samsung Cameras
How do I get my samsung hmx-F80 52X OPTICAL ZOOM CAMERA out of standby mode
jackboy
  • 2985 Answers
SOURCE: Optical viewfinder zoom isn't working
no ideas on how you can get it working. There is I should think a connection adrift. Try the Konica Tech Support Team But be prepared for a zilch answer- I don't think a 'repair' will come into the equation
Posted on Jul 03, 2007
t00nz
  • 4738 Answers
SOURCE: optical zoom problem in movie mode
Your camera is not broken. That's by design. Canon cameras do not allow optical zoom use while in movie mode. Canon claims that using the optical zoom in movie mode would cause excessive noise in the movie. However, you can use digital zoom in movie mode. You'll need to go into the menus (press the menu button) and turn digital zoom "on" if it's currently off.
Posted on Oct 11, 2008
jonniewalker
  • 1029 Answers
SOURCE: How to cancel
The Green mode locks out the user from the camera menu. To cancel the Green mode you must press the Green button again.hope this helps
Posted on Apr 07, 2010
Obertelli
  • 3006 Answers
SOURCE: when I turn my camera on I get a "zoom error" in
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Samsung service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 09, 2010
  • 11967 Answers
SOURCE: The optical zoom has stopped working when I am in
This is a lens problem.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 16, 2011
Testimonial: "Very helpful advice, clearly explained, but it did not work for my problem, which looks as if it is more fundamental."
I can't view my photos and videos in my camcoder
Can you view them through the computer by downloading them? If so your view screen is defective.
Oct 14, 2016 | Samsung HMX F90 HD Camcorder, 5 Megapixel,...
Can I use this camera as a webcam?
i DO NOT THINK SO.
iT'S WAY MORE SOPHISTICATED BUT CHECK THE USER MANUAL PG 85 AND 86
52X Optimal Zoom HD Camcorder Black F90BN Samsung
2 VIDEOS:
Jul 29, 2016 | Samsung HMX F90 HD Camcorder, 5 Megapixel,...
Why does camcorder turn off when I conect it to my DVDs vcr combo to record on vhs tape
Some camcorders will only let you transfer footage when the camcorder is mains-powered. This is so that the camcorder does not run out of power while doing the transfer.
Mar 02, 2016 | Samsung HMX F90 HD Camcorder, 5 Megapixel,...
How do I reset camera to original state?
Have you removed the batteries to try to reset it? The manual should help. If you lost the manual, you can get one online, Google the "make, model and manual" and you will find a .pdf file of the manual that you can save to your computer.
Mar 07, 2015 | Samsung HMX F90 HD Camcorder, 5 Megapixel,...
How do I enable samsung tl105's digital zoom?
From the manual:
Optical zoom TELE : Push the Zoom W/T lever to the right to
enlarge the subject.
Digital zoom TELE : Push the Zoom W/T lever to the right again
in optical 4x zoom mode to enable digital
zoom (software tele). Release the Zoom
W/T lever to stop digital zoom (tele). When
the 5X digital zoom reaches its maximum
magnifi cation, it will not enlarge the image
further, even if you push the Zoom W/T
lever.
Jul 18, 2010 | Samsung TL 105 Digital Camera
Optical zoom problem in movie mode
Oct 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Cameras Logo
56 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
