When i switch on the fuse bursts - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Shorted component/s at its main power regulator [SMPS] board. Check and replace them, or replace the SMPS board as card basis.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 02, 2015
  • 50 Answers
Replace the power cord (FYI - they plug into the back using a standard power cord - computers and other home electronics use the same cord) with another and retry. Often these will get pinched or a screw ran through it (when inside a wall) to cause a dead short. This is a significant issue, so if the new cord doesnt correct the blown fuse then have it professionally repaired. DEAD SHORTS BURN DOWN HOUSES SO PLEASE DO NOT TAKE IT LIGHTLY!
Best WIshes!
    Top Expert:
  • 51,186 Answers
You have a dead short someplace probably in the power supply.
  • majid
    majid Apr 03, 2015
    first of all check rectifier diode from main power supply and then check power supply regulater and all transister.. after that chek zenor diode and signal diode.... the fuse that burns its show short circuit in main power supply
While capturing pictures recording more than one picture
Check whether you are on burst mode. Burst mode will take more than one photo. Try switching back to the standard modes and disable burst.
Nov 03, 2012 | Sony CyberShot 18.2 Megapixel Black...
98 shadow ace-750.burst the main fuse,I changed it as soon i started the bike it burst again what next
remove the winker switch on right hand inspect push button spring.if is fine.follow harness to male and female plugs if fine.check the cable from starter solenoid to starter motor if is piled or burnt, run continue test signal for leakage finally test starter motor if is bridging. end of story.
Jun 20, 2012 | Motorcycles
I have no power to heater on my hilux 2.4 wellside
hi,left key on and moved plugs connecting to alternator and heater burst into life, wire in plug was broken so replaced plug and heater running sweet.
Apr 21, 2012 | Cars & Trucks
My driver power seat wont go backwards or foward and i have changed the fuses which was blown,what could be the problem?
i had same issue and ended up having fire in control switch was lucky i forgot my phone and had returned to car as it burst into flames be careful and i would replace whole unit now
Jul 07, 2011 | 2000 Saturn L-Series
I have a whirlpool dryer mod #LER5620KQ1 that suddenly went dead. Any ideas on what I need to do?
First thing yall do is check for reasons why the dryer would quit. The most common being air restrictions. themobilian_2155.jpg
Your dryer has a fuse right there beside the filter housing. When the drum temp exceeds 350f rapidly this fuse melts and kills power to the door switch. themobilian_2156.jpg
If the fuse is fine then check the door switch
I have a manual and more repair photos HERE
Apr 06, 2011 | Whirlpool Dryers
Samsung DVD player Model P460D Capacitor across the rectifier diode got burst, Fuse blown off due to voltage fluctuation / over voltage. after replacing the fuse and removing the bursted capacitor the...
Only if the power supply has been restored back with the replacement of the capacitor and fuse can we proceed forward. If not you will need to check the SMPS unit to replace damaged components to restore the supply.
If supply seems correct, then check the +5 to the processor unit. In event of high voltage it is possible that the mother board is affected.
Jan 18, 2011 | Televison & Video
Machine fills but wont do anything else
try the Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or your motor coupling could have broken!
Jan 09, 2010 | Washing Machines
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
Televison & Video Logo
Top Televison & Video Experts
