Baxi back boiler keeps gurgling and rumbling then knocks off any help please
  • gbob59 Apr 02, 2015
    Hi David Waddington, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Vincent Schnittert
    Vincent Schnittert Apr 03, 2015
    you may need to check the heatexchanger and see if it is cloged or if the unit has one take a picit has a condensate
  • 37 Answers
Gas or oil if oil when was the last time you had service on the unit? If reasonable amount of time probably wrong nozzle you want more info need to know what type of boiler gas or oil e mail me at vschnittert@gmail.com I can probably walk you through it
Posted on Apr 02, 2015
  • David Waddington
    David Waddington Apr 02, 2015
    It's gas and was serviced about 7 months ago. It's had a new thermastat and new circuit board . Any advice is welcome
  • David Waddington
    David Waddington Apr 03, 2015
    There isn't a problem when it's just the hot water turned only when the central heating is on
  • 36 Answers
SOURCE: i got a baxi combe boiler empty and cleaned the
you may have back syphen or not enough fall on the waste pipe,check condensate tank is switching on when water level reaches switch.
if it does not then replace tank.
Posted on Jan 24, 2010
  • 2550 Answers
SOURCE: got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Posted on Feb 20, 2010
  • 2550 Answers
SOURCE: Where do I turn the heating up on my Baxi combi
go to www.baxi.co,uk and you can down load maunals which should help you as they have most thing in them on how it all works , and it is yours to keep
Posted on Mar 09, 2010
burty681
  • 56 Answers
SOURCE: MY BAXI BACK BOILER IS HEATING THE RADIATORS FINE
yes there is on your cyinder but it mite be the 2port or 3port vavle what is the problem or slugde in the system
Posted on Jan 22, 2011
  • 2550 Answers
SOURCE: were can i get a mannual for a baxi bermuda 50/5inset back boiler fire
You can download one from there wed site baxi potterton wed site
Posted on Apr 11, 2012
I am wanting to wire a Baxi 105E boiler to a Danfoss 102 mechanical timer. The boiler has 5 wires = red, blue, earth, black and yellow. The Timer has six terminals = 1 DHW, 2 HTG, 3 COM, I (earth), 5...
1) Contact baxi:
http://www.baxi.co.uk/contact.htm
2) Which boiler wires? I don't know. Page 24 manual.
Manual says to disconnect link between terminals 1 and 2, and instert timer in-line.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Baxi/Combi%20instant%2080E%20&%20105E.pdf
2) I can tell you about the timer wiring.
Timer is 230Volts
Not sure if you have British Hot-Neutral 230Volt, or Hot-Hot 230Volt.
Wiring is same 2 wires, but words to describe are different.
Let's say you have Hot-Neutral 230V
Connect Hot to L6
Connect Neutral to N5
This will power the timer so it runs and keeps time.
You can get Hot-Neutral wires from Hot-Neutral that arrive to power the boiler.
Now the timer terminals are separate.
E terminal is Earth or ground.
The Common is Hot wire.
The timer then turns on-off and switches back and forth between DHW and HTG.
HTG is heating
DHW is defrost.
Timer has 2 sets contacts.
When timer activates first set of contacts, then DHW defrost terminal receives power from Hot wire on Com terminal. At this time, all power is cut to HTG heating terminal.
When the defrost cycle ends, then the heating circuit receives power, and then the timer has programming that opens and closes a second set of contacts going to HTG heating terminal.
Which wires from boiler connect to each terminal, I am not sure.
Feb 03, 2013 | Hardware & Accessories
I would like some instructuctions for setting the timer on a baxi 105 he boiler please
Hello. Here is the requested material.
www.baxi.co.uk/docs/Baxi_Combi_105_HE_User_Instructions.pdf
If this has helped, please rate it a four-thumbs up. Thank you.
Mar 27, 2011 | Hardware & Accessories
Instructions on how to re light my pilot light onb a baxi bermuda back boiler picture if possible thanks
http://www.baxi.co.uk/products/bermuda-back-boiler-unit.htm?view=download , i hope that will help
Feb 16, 2011 | Heating & Cooling
I need a manual for a baxi solo he 15 Help !!!!!!!!!!!!!
http://www.plumbnation.co.uk/site/baxi-solo-24-he-boiler-natural-gas/Baxi%20Solo%20User%20Guide.pdf i hope this will help
Feb 09, 2011 | Heating & Cooling
We have just moved into an old house with a Baxi open fire and have no idea how to use it. Do all Baxis have boilers? How do we find the model name/number? Is there any risk in using it if the backplate is...
baxi do boilers they are on the baxi potterton wed site, but they are gas would not use with the back platecracked this old fire place you may have trouble finding parts if any , try someone one that deals with woodburners of fire places , they could well be you bestline to go down or a chimney sweep
Oct 15, 2010 | Heating & Cooling
Where do I turn the heating up on my Baxi combi boiler please? Can`t locate anything that looks like a temperature guage.
Mar 09, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Feb 20, 2010 | Heating & Cooling
My boiler(baxi luna HT330) keeps going into E1 fault mode.
After you pressure system do you bleed the rads then top up again .
Jul 19, 2017 | Water Heaters
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
How to light pilot light on back boiler?
Hi. we have a baxi bermuda. I know that you need to hold in the silver button on the left while repeatedly pressing red/ignighter button until pilot is lit. Hold in the silver button for at least another 30 seconds.
Good luck, ours wont light anymore so was on here looking for advice.
Cheryl
May 07, 2009 | Kitchen Ranges
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
