Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
Suspect door spring/assembly broken. How do I repair same?
  • LG Master
  • 2,992 Answers
If it's like my whirlpool, pull it out. Spring should be obvious. I doubt the hinge portion is broken. Spring may be. While it's out and springs tend to break, I would replace both. Several online appliance parts stores can help you with springs, my diagnostics and Hinge issue. They have been helpful to me.
Posted on Apr 02, 2015
Testimonial: "Figured it out myself, had to pull out dishwasher, remove side panel. LG door has spring with connector assembly made from a cord. This connects the spring to the door, to create tension. Ordered part from LG. Replaced both connectors while I had the washer out."
Door does not stay closed
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
The service manual for the R-408LS (the model you posted it under) is here.
You can order parts from the Sears Parts Direct Web site.
Oct 26, 2013 | Sharp R408LS Stainless Steel 1100 Watts...
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I have a frigidaire model fmv156dbf and the door latch will no longer operate. when i opened up the door i saw that the spring that is supposed to operate the latch was no longer attached. where the spring...
We have the service manual and have uploaded it to our site here to help you.
You can order parts here if needed.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 26, 2010 | Frigidaire Microwave Microwave Oven
Microve latch/spring assembly ... have a broken head on the latch which i can repair but cannot see where to attach other side of spring on Maytag MMV5207bas
Unfortunately, the exploded views do not show the innards of the door.
So as new latch head is not available separately, so if you cannot fix yours, a whole new door will be needed.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
There's probably a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
You can use use epoxy and some kind of hardware to fashion a new spring mount.
If you have to do any gluing, make sure the parts are squeaky clean and dry before you glue them, or it will not hold up.
Oct 30, 2009 | Microwave Ovens
Broken door catch, possible spring, Panasonic Slimline Combi microwave oven NN-A554W.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
We have critical safety & disassembly info at our site, linked here.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Nov 26, 2008 | Microwave Ovens
Microwave broken door latch
The door latch head (hook) is pretty easy to replace or repair if that's the issue.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a panasonic slimeline combi microwave and the plastic hook which helps keep the door locked is broken, therefore the microwave will not work
Of course the door latch head (hook-like device) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
Sep 23, 2008 | Panasonic Microwave Ovens
Spring for the door latch is broken
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | Sharp R-1480 Microwave Oven
Need door assembly diagram to replace door latch & spring on Panasonic microwave model nn-t964sf
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Jul 23, 2008 | Microwave Ovens
MIcrowave
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
128 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
