Question about New Bright Bright Holiday Express Train Set
Is it possible to obtain a circuit diagram or schematic?.
The coal (battery) car connections are rusted out and the wires detached. The unit uses a New Bright 181 Rev.3 board. Thanks, Scott
2 Suggested Answers
  • 5 Answers
SOURCE: locomotive won't come on
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Posted on Dec 24, 2009
Fuse layout for a 06 ford expo, cig lighter went out on front and back
The fuse panel diagram should be printed on the inside if the fuse panel cover.
Feb 03, 2018 | Ford Cars & Trucks
Where can i obtain a wiring diagram
There are many places that you can obtain wiring diagrams/schematics. But- you have to be specific on what diagrms/schematics you are looking for.
If you are looking for a diagram for a car/truck, you can usually find wht you need online at specific forums. For instance: If I were looking for a wiring diagram for a Chevy Truck, I would go to a Chevy Truck Forum, etc..
Mar 06, 2015 | Cars & Trucks
I have a 2002 trailblazer that someone decided they wanted my battery more than I did so they cut all my wires. I replaced wiring harness with great care. I tried to start the vehicle and vehicle was as...
You might have gotten the wires crossed or mis-matched.
Obtain the wiring shop manual for your vehicle and use the schematic to check your connections.
If still no avail obtain a volt-ohm meter and use it to trace your circuits, a wire could be loose.
Oct 24, 2017 | Cars & Trucks
How do I obtain Schematics and diagrams for wiring
They do not exist. Forest River may build three of the same unit side by side at the exact time and everyone of them be wired differently. I worked for a dealership that sold Forest River products exclusively and it was a real night mare at times.
What are you trying to repair or locate?
Jul 01, 2014 | Forest River 2011 Lexington GTS 235S
What wire connects the timer to the bed to turn it on?
Woah! can you give a picture of the tanning bed and its connections also? is the timer part of that relay board or is it separate, may i also have a close up of all the connections- the reason i ask is because a lot of this stuff is built "out of standard" (no standard way of doing it), not saying your is but unless someone has this unit and has had this issue before with the exact unit it will be difficult to help you, I take it you could not obtain a wiring diagram. What you want is what we geeks like to call "dirty work", we attempt to fix,correct or complete a circuit without the schematics or knowing anything about the intended design and proper operation of the circuit- in this case we like to rebuild ourselves however thats not always a choice, in which case we trace the circuit and use knowledge of our technical background to complete the circuit as we expected it to operate. if you provide additional video/pictures this is what I would be attempting to do for you... good luck! more question just ask
Mar 30, 2013 | Electrical Supplies
I need a schematic diagram on the controler of the H136 Hot tub . The wires to the temperature abd Hi/Limit sensor have been cut (chewed) I need a schematic to determine the sensor location and the control...
If you go to Google and type in H136 hot tub wiring diagram it should provide multiple diagrams as well as Youtube videos on how to wire a hot tub.
Jan 29, 2018 | Garden
Front panel audio connection to the asus motherboard
hokuwho,
you seem to have found what i seek. im looking for a schematic for my dell latitude d600 to determine which pins of the 9 or so pin battery connection on the mother board require which voltages and or resistances to both supply the 11.1v battery voltage to run the computer, and the other signals voltages resistances etc from the two circuit borads inside the battery case that tell the computer to use the perfectly good fully charged li battery cells or not depending on number of charge cycles. my batttery stopped putting the 11.1 v, it still has alive and well inside, out to the computer mobo, and has stopped charging, or so the computer says, eventhough its fully charged, and yet will not run the computer. i ordered another battery and know why dell in thier infinite though misguided wisdom decided to prematurely kill the good batteries to avoid possible overheating and exploding. but i want for my own knowledge to determine how they are killing the output and possibly design my own circuit that does what they actually needed and meant to do, rather than have the number of charge cycles rule. id just detect battery temperature and ability to charge, and eliminate any counting of charge cycles which is useless, and results in killing perfectly good batteries for no reason. do you know what numberds i actually need to find a schematic. each time i attempt to search with the computer model number, i find schematics of other mfgrs completely different equipment with d600 in the model number, or rar files i cant open, and usually with added notes that downloading this file can harm my computer.
i have always built my own desk tops and fear no electronic circuit but software and file suffixes and wanings of damage to my computer and various types of files apparantly engineered only to confound and confuse give me a little trouble. i started in electronics at a time when each simple circuit stage was built around a single huge glass tube the size of a body builders forearm. and now im working on entire computers with less surface area than one of those tubes. but back when those tubes ruled, manufacturers were trying to build the best longest lasting curcuits they could and drew schematics that actually were intended to be capable of being read by any good tech, and were easy to find with model number, of the equipment. given a schematic i can repair most anything but i cannot find the schematic. but current circuits are desigend to purposely fail for no reason that makes sense so the manufacturer can sell more to replace them, and schematic are well disguised not only in the way thier drawn and marked but even where they are located. ive learned to read nearly all schematics and interpret any schematic symbol, but locating schematics online and getting them to my computer, is difficult for me, eventhough i have desigened and built my own electronic circuits my self all my life.
Nov 15, 2008 | Computers & Internet
How could i possibly obtain a schematic wiring diagram on a `99LexusES300,and location of control module & relays.
go to the lexus dealer where you live and ask for the schematics they are usually happy to help
Aug 13, 2008 | Lexus ES 300 Cars & Trucks
New Bright Bright Holiday Express Train Set Logo
55 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
