Question about Electrical Supplies
How do I test ignition coil for spark from onan 4000 generator
  • cheryl hargrave
    cheryl hargrave Apr 04, 2015
    How do I know if an ignition coil is working correctly as I am not getting a spark at the spark plugs. I have replaced the spark plugs and the high tension wires.
    Top Expert:
  • 10,875 Answers
Get one of these,
how do I test ignition coil for spark from onan 40 - 25623736-teeiiwmuxvqv3cdwpzoednoy-2-0.jpg
Posted on Apr 04, 2015
My onan 4.0 grenerator motor will not idle and it is back fireing while trying to run is in the valves
If it is backfiring even during idle, there are a couple of possible issues. Check the obvious and least expensive first. Make sure you have correct OEM spark plugs, check ignition wires. Then check the ignition coil and trigger module, there is a procedure for doing that in the Cummins Onan manual. A manual can be obtained from http://www.advanced-power-technologies.com/ or local Onan RV dealer. This will give you the ignition coil resistance and the ignition module resistance. Also has anyone messed around with the carb, or has it sat for long periods, too lean a fuel mixture can cause backfiring. Good Luck ;)
Feb 11, 2015 | Onan CUMMINS 4.0 KYFA/6747 - Cummins...
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 generator has no spark
If there is no spark, the ignition module may be bad, or the wiring to it. Have the module ohmed out. Also the magnetic trigger assembley that is on the rotor that sweeps past the ignition module maybe broken. If they check ok, suspect the control board
Mar 23, 2013 | Onan Microquiet 3600 & 4000 Generator
I have a 6.5 onan generator will not fire or spark
If you are sure all the correct switches are thrown to start this unit, than you need to turn your attention towards the coil. It might be toasted and need to be replaced. Make sure all connections are good before replacing. Good Luck...
Sep 26, 2011 | Watts Onan Portable Generator - 4000 ,...
I have a micro quiet 4000 starts up but surges up and down , could it be just old gas making it run so bad
The reason can be:
  1. Bad or loose ignition (spark plug, magneto, coil cable etc);
  2. Water in the gas;
  3. Dirty fuel strainer;
  4. Not set on level surface;
Jul 10, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
70 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
