How to re pin a dual xdvd3105bt colors - Computers & Internet
  • 1,602 Answers
No power to pci-e and usb ports
if you have a volt meter, take the negative lead and place on a black/neutral pin in the PCI-e cord. Then take the positive lead and check all colored pins (typically yellow) for voltage. Yellow wires are 5volts and red is 12 volts...if there is now power when testing, you have a failed power rail and the power supply must be replaced
Feb 05, 2014 | eMachines ET183107 Desktop PC Intel...
Need pic of power hook up to mother board
How about the motherboard manual instead?
http://support.asus.com/Download.aspx?SLanguage=en&m=P4P800+SE&p=1&os=
To the right of the - Select OS - box, click on the blue Down Arrow.
Click on WinXP
(Doesn't matter which Operating System is chosen, we're just going after the motherboard manual)
Scroll down, click on the + sign to the left of Manual (10)
Scroll down, go to the 4th file down -
Version E1886
P4P800 SE User's Manual English Version E1886
Right underneath this file name click on the Blue - Global
Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on Global, it may take up to 30 seconds before the first page comes up.
At the Top of the Adobe Reader is the page number box. It is to the right of Page: and the Down Arrow.
You can go page by page to arrive at the page you want, or if you know the page you want; perform this,
1) Put your mouse cursor in the page number box, to the Right of 1
Left-click once. Now backspace the 1 out.
2) Type the page number you want.
3) Press the Enter key
Go to Page 25 - 2.2.3 Motherboard Layout
[Use the Zoom Out icon at top ( - ) by clicking on it, to decrease the view size.
Use the Zoom In icon ( + ) to increase the view size ]
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel connect to; is the Front Panel header.
Goes by many abbreviations.
Here we see it is PANEL_1
Two rows of 10 contact pins.
Now go to Page 55 - 12. System Panel Connector
I see no numbering system is used, so I will number the pins.
The Top row is numbered EVEN.
The Bottom row is numbered ODD.
Starting on the Top row, going from LEFT to RIGHT,
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
Starting on the Bottom row, going from Left to Right,
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pin 5 is N/C. Not Connected. Don't even know if the pin is there, or just a blank spot. (But you will)
C) Pins 7 and 9 are for a SMI lead.
"System Management Interrupt Lead (2 pin SMI)
The 2-pin connector permits switching to suspend mode, or "GREEN" mode, in which system activity is instantly decreased to save power and to expand the life of certain system components. Attach the case-mounted suspend switch to this 2-pin connector."
Suggest leave alone.
D) Pins 11 and 13 are for the Power On switch.
E) Pin 15 is N/C. (Or again, may not be there)
F) Pins 17 and 19 are for a Reset switch, IF a Reset switch is used.
G) Pins 2, 4, and 6 are for a Power On LED. (Light)
A 3-wire Power On LED.
Pin 2 is for a Positive ( + ) wire.
Pin 4 is for a Positive ( + ) wire
Pin 6 is for a Negative ( - ) wire.
This is for a Power On LED that is Dual Color.
Used back in the day when there was Turbo Mode, and Normal Mode.
A farce in reality.
Turbo Mode WAS the normal mode, while Normal Mode was a lesser version.
Usually a Green/Yellow dual color LED.
Green - Turbo, Yellow - Normal.
One side, or can be said as color; of the LED went to Pin 2.
The other side, or other color, went to Pin 4.
Ground (Negative - ) wire goes to Pin 6.
If using a Single color LED, (2-wire), suggest connect Positive ( + ) wire to Pin 2, and Negative ( - ) wire to Pin 6.
H) Pins 8, 10, and 12 are for Bambi to use, when running around without spots...
NO!..............you gonna' believe that, geez?
I just wanted to see if you were following along, after the dual color LED thing.
Pins 8, 10, and 12 are N/C.
I) Pins 14, 16, 18, and 20 are used for a small internal speaker.
Used to hear BIOS Beep Codes.
Pin 14 is for the Positive ( + ) wire
Pin 20 is for the Negative ( - ) wire.
Also uses a 20-pin ATX main power cable, (Right side of Ram Memory slots),
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
,and a 4-pin ATX +12 Volt power cable, (Bottom left corner of processor socket),
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P4P800 Motherboard
Need emachines t3306 motherboard connection diagram
The eMachines T3306 desktop computer, uses the FIC K8M-800M motherboard.
First International Computer, (Inc)
http://www.fic.com.tw/product/motherboard/amd/ficimages/k8m-800m.jpg
http://www.fic.com.tw/product/motherboard/amd/k8m-800m.aspx
Here's the download page for the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Column in middle, 3rd file from bottom.
This is a Zip file. A Zip file is a Compressed file. Used to send large amount of information more easily.
Has to be decompressed, or 'unzipped'.
After you click on the blue -> FIC K8M-800M file name, a small window will come up-
Opening K8M-800M_manual.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the empty circle to the left of Save File.
No go below in the small window, and click on OK.
A small download window will come up.
Allow the file to fully download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with a zipper on it. K8M-800M_manual.zip is to the right)
In the next small window go to the far Left, and click on -
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name ->
K8M-800M_manual
(Next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
For an example;
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, the Front Panel header is at the Bottom/Right.
The Front Panel header is Orange in color. (Page 20)
Two rows of contact pins.
5 pins across the Top row.
4 pins across the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the RIGHT side going across to the Left; Top row,
Pins 1, 3, 5, 7, and 9.
Starting on the RIGHT side going across to the Left; Bottom row,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
Reserved for factory use. Probably a 5 Volt test point.
D) Pins 2 and 4 are for a Power On LED light.
These two pins are used for a Single color, Power On LED light.
Two wire LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
There is ALSO a jumper used for this LED light. More on it at the end.
E) Pins 6 and 8 are for a Power On switch.
To the Right of the Orange Front Panel header, (F_PNL), is the PW_LED header.
[Page 20 to right of Front Panel header. -> PW_LED
(Power LED, 2/3 Pins) ]
3-pin Black header. Sits Vertically.
(The Orange - Front Panel header, sits Horizontally)
This is used for a 3-wire Power On LED light.
Used for a Dual Color - Power On LED light.
One example is if the computer has Turbo Mode, and Normal Mode.
Green color usually for the Turbo Mode, Yellow color of the LED for the Normal Mode.
Starting from the BOTTOM going UP;
Pins 1, 2, and 3. (3 at the Top)
A) Pin 1 is for the Positive ( + ) wire. [Signal]
B) Pins 2 and 3 are for the Ground wires.
Jumper block for the 2-wire Power On LED light, and 3-wire Power On LED light; Page 13 - Set System Jumpers
(Actually it starts on Page 12)
6-pin header to right, of 3-wire Power On LED header.
Has Blue jumper caps on it. Two of them.
(PL_LED1)
http://www.ebay.com/itm/NEW-FIC-uATX-Skt-754-AMD-Desktop-Motherboard-VIA-K8M800-AGP-4x-8x-DDR400-800FSB-/280923928691?pt=Motherboards&hash=item41685ef873
Two rows of 3 pins.
The bottom row is numbered EVEN.
Starting on the RIGHT side going towards the Left; Top row,
Pins 1, 3, and 5.
Starting on the RIGHT side going towards the Left; Bottom row,
Pins 2, 4, and 6.
A) With the jumper caps on Pins 3 and 5; plus 4 and 6; the Power On LED light works as a Single color LED.
B) With the jumper caps on Pins 1 and 3; plus 2 and 4; the Power On LED light works as a Dual color LED.
Regards,
joecoolvette
Mar 07, 2013 | Computers & Internet
I need the total wiring diagram for camera [8pin rj11]
8 pin RJ45 (8P8C) male connector
at the camera output
LG LVC-CY100NM Color Security Camera with 8-pin RJ45 (and other cameras for the LSP-M1017M Dual Quad Observation Systems by LG)
Pin
Number Pin
Name Description 8 SPK Speaker (Hot) 7 VID Video Out 6 GRN Ground 5 SPK- Speaker (cold) 4 AO Audio Out/Alarm Out 3 VDC 12VDC 2 N/C RS-485- 1 N/C RS-485+ Note: Pin numbers are labled backwards in the manual (corrected above).
The camera is adaptable for use in any composite video application with the use of a balun.
on the output. I had noise-less video and clean audio across a 350 foot run of cat 5e.
Jan 29, 2013 | LG LVCCy100NM Color Security Camera with...
MSI 760gm-p21(fx) MB, JFP1 AND JFP2 PINOUTS I NEED TO SEE A DIAGRAM SHOWING ME EXACTLY WHERE TO PLUG the cables on the MB
http://www.msi.com/product/mb/760GM-P21--FX-.html
Hover your mouse cursor on the Download tab.
(Overview/ Specification/ Download/ Support/ Where to Buy)
In the drop down list click on - Manual
On this page under the subheading Download, click on the blue -
M7641v3.0.zip
On the next page click on the country name nearest yours.
Motherboard User Manual.
This is a Zip file. If you do not know how to open a Zip file, please state in a Comment, and I will guide you.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is divided into two headers on the motherboard.
This you have stated, JFP1 and JFP2.
(Junction Front Panel 1, and Junction Front Panel 2)
JFP1 is for the Power On switch, HarDDrive activity LED, Reset Switch, and a two wire Power On LED.
JFP2 is for an internal speaker/buzzer, and a three wire Power On LED. (Dual color)
JFP1:
4 pins across the Top row.
5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side coming across to the Right side, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the LEFT side coming across to the Right, Bottom row;
C) Pin 9 is N/C. Not Connected. It is reserved for the factory to use.
D) Pins 2 and 4 are for a two wire Power On LED.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO pin 10.
JFP2:
3 pins across the Bottom row.
Starting on the LEFT side coming across to the Right, Top row;
Pins 1, 3, and 5. There is NO pin 7.
A) Pins 1, 3 and 5 are for a dual color Power On LED.
Pin 1 is for the Negative ( - ) wire.
Pin 2 is for a Yellow, or Orange part of the dual color Power On LED.
Pin 3 is for a Green part of a dual color Power On LED.
B) Pins 2, 4, 6, and 8, are for a speaker/buzzer.
Pin 2 is for the Negative ( - ) wire of a speaker.
Pin 8 is for the Positive ( + ) wire of a speaker.
Pin 4 is for the Positive ( + ) wire of a buzzer.
Pin 6 is for the Negative ( - ) wire of a buzzer.
Regards,
joecoolvette
Jul 28, 2012 | MSI Computers & Internet
I need a wiring diagram to install my Ultra Durable Motherboard model GA-Z68MX-UD2H-B3
This is Gigabyte Support, and the main support page for the Gigabyte GA-Z68MX-UD2H-B3 motherboard,
http://www.gigabyte.com/products/product-page.aspx?pid=3854#ov
On this page I invite you to click on the Downloads tab.
(Overview, Specifications, Downloads, News/Awards, etc)
To the right of the Download Type box, click on the blue down arrow.
Click on Manual.
You want the third file down,
English - 1001 - pdf - 28.91MB - 2011/05/02
Under the Download Here heading, click on the name of the country nearest yours.
This is a PDF file. It may take up to 30 seconds before you will see the first page.
It may also take additional time for the file to fully download.
(The computer you are using now has Adobe Reader on it, which uses PDF files)
[ I'm using Adobe Reader X (10), and a medium speed DSL connection. Took over 65 seconds to download, clicked on America. Longest PDF file download I have had in a long time ]
Page 7 shows a layout of the motherboard.
Processor to the Top, Ram Memory to the Right, the Front Panel header is to the bottom right corner.
{The plastic front of your computer is the Front Panel.
The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
F_PANEL }
Page 23
10) F_PANEL
Page 28 - Front Panel pinout
The Front Panel header is parallel to the bottom edge of the motherboard, and lays out horizontally.
Two rows of 10 pins. Total of 20 pins.
The Top row is numbered Evenly. Pins 2 through 20.
The Bottom row is numbered Odd. Pins 1 through 19.
A) Pins 6 and 8 are for the Power On switch.
(If there is a Positive { + } wire it goes to Pin 6)
B) Pins 10 and 12 are not shown. No Pins 10 and 12.
Pins 14, 16, 18, and 20 are for an internal speaker.
This speaker is used for BIOS Beep Codes.
C) Pins 1 and 3 are for the HarDDrive activity LED light.
The red LED that blinks when the harddrive is actively in use.
(Pin 1 is for the Positive wire { + }
If the LED light is dim when operating, switch the wires )
D) Pins 5 and 7 are for the Reset switch, IF used.
(You can go through Task Manager, and do the same thing.
OR you can also simultaneously press the CTRL, ALT, and DELete keys)
E) Pins 9 and 11 are for a Chassis Intrusion switch.
If the computer cover is removed there is no power to the motherboard.
This is IF a chassis intrusion switch is connected to these two pins.
It may have the style that the switch is in the open position, allowing No electricity to pass through to the motherboard, when the computer cover is removed.
Or it may have the style where the switch closes, and connects to Ground, when the computer cover is removed. Again no electricity is allowed to pass through to the motherboard.
Test to see which way works. Jumper wire across these two pins.
Default setting is probably nothing connected to these two pins.
F) No Pin 13
G) Pins 15, 17, and 19 are for the Power On LED light.
There are three pins for using a dual color LED light.
Pins 15 and 17 are for the Positive wires.
One pin goes to one color (Side) of the LED light, the other pin is connected to the other color (Side) of the LED light.
Pin 19 is for the Ground { - } wire.
Dual color LED lights were used if a computer had 'Turbo' mode. The computer was supposed to operate faster in Turbo mode.
In reality the computer operated at normal speed in Turbo mode, and lesser speed in the normal mode.
If your Power On LED light is a single color LED, connect the Positive { + } wire to Pin 15, and the Negative { - } wire to Pin 19.
As for the wires coming from the Front Panel, you'll have to trace them down to see what is what.
Power On switch wires, Power On LED wires, etc.
Regards,
joecoolvette
Jul 24, 2011 | Computers & Internet
My power led connector (green,white) power sw connector (black,white) got out of place and i dont where they go
The eMachines T3302 desktop computer, uses an FIC K8M-800M motherboard.
(First international Computer, Inc.)
Where those wires go on the motherboard, is termed a Front panel header.
The Front Panel is the plastic front bezel of your computer.
(Where the Power On button is, Power On LED light, and so on)
Looking at the motherboard with the Processor to the Top, Ram Memory slots to the Right, the Front Panel header is at the bottom right corner, and over to the left.
Look at the jumper block in the bottom right corner. Right in the corner.
This is the LED type selector, jumper block.
Has 6 pins.
3 across the Top, 3 across the Bottom.
(This jumper block is to set whether you are using a Power On LED light, that has Dual Colors, or a Single color.
The default setting of the jumper on the block, is set to use a Dual Color LED light, for the Power On LED)
Move to the left of this jumper block. The Front Panel header is to the left of this jumper block.
(FIC terms it a Front Panel Block Connector)
It should be White in color.
Is right against the bottom edge of the motherboard. (Parallel to the outside edge of the motherboard)
Has two rows of pins sticking up.
5 across the Top.
4 across the Bottom.
The pins are numbered from the Right, going towards the Left.
(From the Power On LED jumper block, towards the Front Panel header)
On the Top row going from Right, towards the Left,
Pins 1 ,3, 5, 7, and 9.
On the Bottom row going from the Right, towards the Left,
A) Pins 1 and 3 are for the Power On LED light.
(Green)
B) Pins 5 and 7 are for the Power On switch.
Pin 5 is for the Positive ( + ) wire.
(Black)
[Although it really doesn't matter which way the wires go. It's a SWITCH]
C) Pins 2 and 4 are for the HarDDrive activity LED.
Pin 2 is for the Positive wire ( + )
D) Pins 6 and 8 are for the Reset switch.
(IF used)
If any of your LED lights are dim, after attaching the Positive wire for each LED, it's because the Positive wire is on the wrong pin.
Switch the wires around
Aug 23, 2010 | E-Machines T3302 PC Desktop
I need to know where to connect the three seperate 2 pin connectors from the ''power switch'' to the motherboard on my eMachines C2685 desktop computer.
The eMachines C2685 uses an FIC VC37GV motherboard. (First International Computer, Inc.)
http://www.motherboards.org/mobot/motherboards_d/FIC/VC37GV/
Here is the motherboard manual,
http://www.ime.org.uk/pdfs/vc37_vg31_b1_eng.pdf
After you click on the above link, give it up to 30 seconds to download. This is a PDF file.
Barring you cannot download the file, I will state the connections for the Front Panel header on the motherboard.
(Plus state the page to reference to, in case you can download)
View the first link, with the photo of the FIC VC37GV motherboard.
As shown, Processor is at the top, Ram Memory slots are to the right.
The Front Panel header is located at the very bottom right corner.
It is parallel to the outside edge of the motherboard. There are two rows of pins.
(Page 12)
The Front Panel header has 5 pins going across the top, and 4 pins across the bottom.
The top row of pins are numbered Odd.
The bottom row of pins are numbered Evenly.
On the Top row starting on the Right side, going towards the left, the pins are numbered 1, 3, 5, 7, and 9.
On the Bottom row starting on the Right side, going towards the left, the pins are numbered 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HDD LED. (HarDDrive activity LED)
B) Pins 5 and 7 are for the Reset switch
C) Pins 2 and 4 are for a Dual Color Power On LED, if used.
Green goes to Pin 2. Yellow goes to Pin 4.
Otherwise Pin 2 is Positive, ( + ), and Pin 4 is Negative. ( - )
D) Pins 6 and 8 are for the Power On switch.
(PWR1, or SW1)
There is a small 3 pin header, just above the Front Panel header. (Page 12)
This is for a Power LED that has either two wires, or three wires.
The pins are numbered from Right to left.
Pin 1 is for the Power LED, and Pin 2 is for Ground, if using a two wire Power LED. (Not dual color)
Pin 1 is for the Power LED, and Pins 2 and 3 are for Ground (GND), if using a three wire Power LED.
(Page 13)
May 26, 2010 | Computers & Internet
Second SIM not working
Settings>Dual SIM settings>Select "Dual SIM open>click OK
Jun 11, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
f_Panel
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
Computers & Internet Logo
179 people viewed this question
David Payne
David Payne
